Question about 2001 Mazda Tribute Door, Front g63164243i LX-V6 and ES-V6, Passenger Side Topeka, Kansas
STILL CANNOT FIND ANSWER TO MY PROBLEM
JUST WILL NOT REV OVER4000 RPM & RUNS ROUGH FOR5-10 MINS WHEN COLD RUN GOOD WHEN HOT
  • 1 more comment
  • hossamnada Mar 23, 2014
    Hi jOHN cOERT, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • jOHN cOERT
    jOHN cOERT Mar 27, 2014
    We had a problem with a 2001 mazda tribute v6 would not run when cold. we have since found the problem1 (will not rev over 4000rpm. solution1, Engine not reving above 4000rpm dont worry, that is the engine rev limiter. Problem 2, runs rough & engine stalls when cold runs ok when hot Solution2, running rough & stalling when sold. remove & replace plastic manifold & rep;ace manifold seals. this will fix the ploblem. Inlet manifold gasket 9Premaseal M5-3693 Maifold collector 9Permaseal M5-3694 Best of luck John
  • Tim Marx
    Tim Marx Apr 25, 2014
    and check you're MAF sensor...should come out with a couple screws, then either clean it off good GENTLY and try it...or replace it aee if that helps.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 144 Answers
Sure it isn't ur maf sensor.
Posted on Apr 12, 2014
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
1999 dodge 1500 39 when its cold outside truck starts but runs rough for about 3 min then clears up when its warm outside or it has been sitting it will not start it smelld like its flooding new coil new...
When engines are cold, it is usually normal for them to run a little bit rough due to the EGR valve and the timing of the engine with the manifold and components being cold. It takes time to vaporize the fuel to achieve full combustion. The automatic throttle should activate and put the engine at an RPM approximately 1500 to 1800. At this RPM, you should not run the car otherwise you risk losing your transmission in the long run. It may be also wise to tune up your car by checking the spark plugs, the contact points and the timing mechanism. An erratic timing mechanism can give you a rough idle.
Mar 12, 2014 | Cars & Trucks
Idle problem integra
check the MAP sensor (manifold absolute pressure). The ECM (car computer) uses that to keep idle at minimum 750 RPM. It's normal for it to run high when cold. These small 4 banger motors typically run hot, and they won't run right IF they're NOT running hot, ergo the idle is usually high when it is cold so as to cause it to warm up quicker. If the RPM's drop below 750, suspect the MAP sensor, &/or ECM.
Apr 18, 2013 | 1995 Acura Integra Coupe
50cc running rough when warm
dirty air filter acts like a restrictor which is like leaving choke on. as is ok cold could be this or could be ht lead or ht cap breaking down when hot cos of bad connection
Feb 13, 2013 | Motorcycles
1993 jeep wont rev over 3000 rpm and idles rough
Run a fault code test as a starting point for diagnosis of this problem, learn how to do that here
Sep 17, 2012 | Cars & Trucks
Car rev's up (like a vacuccum leak) only when cold
a vaccum leak doesnt normaly cxause a motor to rev-up it would normaly make it idle low and rough. however if its cold it should run between 1200 and 1800 rpm untill its warm its called a fast idle.
Jan 30, 2011 | Honda Accord Cars & Trucks
My 1986 Ford F-150 5.0 EFI runs good, but when I start it it revs to 1700 rpm untill I give it a little gas then it drops to normal rpm. How do I stop it from the high revs when started?
Does it rev high when started cold or hot? If it does it either hot or cold, check the throttle position sensor on throttle body. If that is not bad, then check the automatic choke sensor.
Jul 03, 2010 | 1986 Ford F150 SuperCab
Rough, shaky hot or cold starts on W202+short pwr loss mins later
Check the cable near the abs modulator. Some C180, C200 have short circuit from broken insulators
Apr 24, 2009 | 1998 Mercedes-Benz C-Class
2001 Mazda Tribute Door, Front g63164243i LX-V6 and ES-V6, Passenger Side Topeka, Kansas Logo
Top OEM Vehicle Parts & Accessories Experts
Bill Boyd
Speedracer70
Tom Chichester
Are you an OEM Vehicle Part and Accessory Expert? Answer questions, earn points and help others
