Question about Shure SLX Series Wireless Microphone System SLX1248558H5 Microphone
Short in wire at plug,cant take plug apart
Wire is broken at plug where it enters the transmitter, not sure how to get it apart, unscrew it or what, afraid ill brake it
  • Lawrence Oravetz Mar 20, 2014
    Hi matt williams, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What wire are you talking about? If it's the one on the very bottom of the mic then that's the antenna. If its under the wire ball on top then the capsule is done. need more info for a good answer.
  • matt williams Mar 20, 2014
    i figured it out, not sure how to get mike wire plug apart, it screws off, it was soaped on or something then the wire is in epoxy, wow, i cut it iff the board plug and redid the whole thing, thanks anyway for the help, Matt
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The mic will disconnect from the transmitter. Simply push the black button and pull outward. Then, the black part of the connector unscrews from the silver part of the connector in order to get at the guts of the connector.
Posted on Jun 24, 2014
1999 ds 80 with light or no spark at all to spark plug
Bad or broken spark plug cap or coil wire,,, check them closely
also the end of the plug needs to be removed ( Unscrewed ) in order for the cap to properly snap on to the plug,
Good luck
Dec 28, 2014 | Motorcycles
How do I take apart a beta52a?
Unscrew the grill and look for a plastic piece that holds the capsule in place. This plastic piece also can be unscrewed and will allow you to reach the PC board inside. Check for broken wiring (most common problem) but low output usually indicates a damaged mic capsule that must be replaced.
Feb 18, 2013 | Shure Beta 52A Professional Microphone
GE JTP20 oven. Do I need to replace light fixture after spark from a short?
First, no First, no First unplug the range after you gently scoot away from wall. Then check youy main circut breaker for house to see if you tripped fuse. Then with stove still unplugged remove back access panel, look to area where light goes into oven. Check again and make sure oven is unplugged, then repair the wire by splicing wire with new wire line splice purchased at your nearest local auto parts store, sales person can show how to install. THEN plug in to see if you can see the light!
Joe Don
May 25, 2012 | GE JTP20 Electric Single Oven
Have a beta 57a it wont work ? nothing
I'm assuming that you have tried the obvious stuff like using a different cable and a different amplifier?
The Shure beta 57a is a very robust and reliable dynamic microphone and there is very little to go wrong with it apart from
  1. A wire broken off inside
  2. A broken capsule - can be caused by dropping it
You can inspect for broken wires by very gently unscrewing the microphone head and peering inside - however the wiring is quite short so be careful not to pull any wires off in the process.
A broken capsule can be replaced - contact your local dealer for parts.
Feb 09, 2011 | Shure SM87 Professional Microphone
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: Light keeps on flashing on the motor...
how many flashes
1-safety sensor wire broken
2-safety senor wire shorted or reversed
3-door control or wire short
4-safety sensors mis aligned
5-motor overheated or bad RPM sensor
6-circut failure, bad logic board
May 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Steering servo makes hard rt turn without turning steering wheel. batteries are fully charged and all connections appear secure. can temporarily eliminate prob by turning transmitter off/on.
2 possible problems:
transmitter-The variable resistor inside your transmitter is stuck fully on. Take apart the transmitter - look for the part under the wheel. It should have a 3 wire variable resistor under there - check for broken wires shorting to the other side or simply broken solder joints.
2nd possible answer is the car has a shorted output drivers on the motor controller board.
hard to fix without a schematic.
the guaranteed seo services provider
Apr 13, 2010 | Futaba 3pm-fs Pro 3-ch Synthesized...
Have a33hml sometimes does not transmitt or rec
take apart the mic where it plugs into the radio.
there are probably loose wires.
make sure to mark each wire where it is hooked up to the mic pins before you start messing with it. Example: red #1..black..#2 ETC ETC.
the mic plug has numbers on it and the colored wires go to certain numbers on the mic plug.
Oct 23, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
Problems with a emaxx truck running right
Here's a few things to check to help you narrow down the problem, if these make no difference, post a reply to this thread with your findings.
First, make sure all your batteries are fully charged, including recharging or putting fresh batteries in your transmitter.
Next, make sure there are no cut, worn, frayed, or broken wires coming from the electronic control unit (ECU) to the motor and the receiver. Also, make sure that the wires are connected with the right polarity, red to positive, black to negative, on the motor.
Then, take apart your receiver box (with the antenna sticking out) and check to make sure all your servo connectors are tight and not corroded or damaged.
Also, with the receiver box open, check to make sure your frequency crystal (silver plug with a colored flag/label) is in tight on both your receiver and your transmitter (it's behind the colored label near the bottom, in the back of the transmitter).
Make sure the frequency crystals are of the same frequency (color and number) on both the transmitter and the receiver. If you haven't changed them out for new ones they should be the same, but you never know. (I.E. if your transmitter has a 27.255 your receiver must have the same exact number, a 27.195 will NOT work with a 27.255 and vice versa)
Next, try purchasing a new frequency crystal set of a different frequency(color) than the one you are currently running. These parts do wear out after a while and even with a new truck they may be defective.
I hope these tips will help you get started and you can always reply with any other questions you may have. If your question is about this problem, remember to post to this thread, I may not be able to find it if you make a new thread for the same problem. Don't forget to rate! Good luck and let me know how it works out!
Dec 23, 2008 | Traxxas E-Maxx 4WD Monster Truck RTR
84 bonneville fuel gage
You need to isolate what the problem is. First, check the power supply/ fuse for the instruments, ensure the gauge has a supply. Check the earthing at both the tank end and the gauge (body). With a meter, you should see 12V. (or maybe less, if the Bonneville has a regulator on the instruments, I don't specifically know the vehicle). This should appear between one of the rear terminals of the gauge and the case, when the ignition is on. If present there, check it is still there when checked between that terminal and another earth point on the car's metalwork.
The other terminal on the gauge is the transmitter termination. If the power is present, removing the transmitter wire should cause the gauge to either go full scale, or not move at all. Use a piece of wire to short this terminal to ground, the meter should do the opposite to the previous test. If no movement, the gauge is faulty. Replace.
At the tank end, you should find the transmitter unit. It should have a single wire connected to a terminal. Remove this. With aan ohmmeter, check for a resistance reading between this terminal and ground. If no meter, turn on the ignition with this wire disconnected, the gauge should do the same as it did when the wire was removed behind the gauge. If it does, short the removed wire of the transmitter to ground, the gauge should do the same as the short test at the gauge, If not, the wire is broken or shorted somewhere between the gauge and transmitter.
If the gauge moves as before when testing from the transmitter wire, most probably the transmitter is faulty.
Too hard? Leave it to the experts...!?! ;-]
May 14, 2008 | 1984 Pontiac Bonneville
Carpet Beater for Central Vac
Some of these types of hoses, if there is a male plug on the end that goes into the wall outlet, could be that one side of it is fused and will have to be replaced. When something happens like a short or a bad brush roll stall, this fuse will open up. If you supplied the model number I may habe been able to look it up and see. But if the hose end cuff comes off, then you can check it with an ohm meter to see if one side is open or not.
Mar 14, 2008 | Vacuums
64 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
