Question about 2001 Mazda Tribute Door, Front g63164243i LX-V6 and ES-V6, Passenger Side Topeka, Kansas
HAVE REPLACED FUEL PUMP & FILTER
WILL NOT REV OVER 4000 RPM HAVE REPLACED AIR FLOW METER FUEL PUMP FILTER
  • Paul Marks Mar 22, 2015
    check for fuel pressure then check fuel rail for fuel and check the Injector,s for power then replace if they need to sounds like fuel rail is week get it checked for pressure
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,449 Answers
Check the seal at your tank if you replaced the fuel pump .it is leaking air .
Posted on Mar 25, 2014
1985 toyota camry unplug mass air flow sensor engine will start plug back in engine dies
There is a switch in the airflow meter that keeps the fuel pump relay closed as long as there is airflow. With the meter unplugged, the pump should not run except when the key is turned to start. It would seem to me that you have a wiring issue. Try jumping the fuel pump relay so the pump runs whenever the key is on. (Remove the relay and jump the pump wire to the accessory wire--see top left diagram.) This defeats the safety feature but will keep the pump running.
Oct 30, 2017 | 1993 Toyota Camry V6
1994 Toyota Camry XLE replaced fuel pump & filter car starts & idles but boggs out and cuts off when pressing gas pedal?
have you pulled codes or checked the fuel pressure? It could be a host of things, like a clogged air filter restricting the flow of air into the engine, a bad air meter, clogged injectors, etc. Engine codes will help you start narrowing things down.
Has the engine air filter ever been changed?
Sep 03, 2012 | 1994 Toyota Camry
Replaced head gasket fuel pump & fuel filter ran
Did you get you part from a parts store or the Dealer?
Jun 13, 2011 | 2002 Ford Escape
My sonata 2001 v6 automatic won't rev past 4000 rpm by any way (idle or by driving) sometimes will shut after trying reving by full throttling. The only code output to my code reader is u0000 and no check...
I would replace the fuel filter(every 35000 miles),check the condition of the air filter and check out the catalitic converter and feel the tail pipe to see if the flow seems clogged and weak when some one else gives it the gas.
My 2001 had to have a new cat at only 44000 miles. I had them install a "High Flow" type.
Oct 30, 2009 | 2001 Hyundai Sonata
My car will only rev to 2500 rpm in drive or in
bad mass air flow meter replace it also check for a ecm update at the dealership goes by vin pretty common problem
Feb 28, 2009 | 2003 Nissan Maxima
Engine light on, bad fuel milage
You didn't mention if you replaced the mass air flow sensor, if the tech got that code, it needs replacing, if you haven't alresdy done so.
Feb 25, 2009 | 1997 Buick.5 Regal
Will not rev over 2000 rpm 2003 hyundai santa fe 2.4 eng
hi there have you check the air flow system (pipes for blockages,pipes that may have split etc) sounds if it is air flow problem.
Dec 15, 2008 | 2003 Hyundai Santa Fe
2001 Mazda Tribute Door, Front g63164243i LX-V6 and ES-V6, Passenger Side Topeka, Kansas Logo
83 people viewed this question
Top OEM Vehicle Parts & Accessories Experts
Bill Boyd
Tom Chichester
 Russ Hill
Russ Hill
Are you an OEM Vehicle Part and Accessory Expert? Answer questions, earn points and help others
