Question about Fisher and Paykel Dishwashers
Fisher paykel repair manual
The lid of the machine is cracked. I have bought a new lid but I' not sure how to replace it. Can You give each any instructions to help Please?
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel DD603 Disher Drawer Service Manual
You can get fisher paykel service manuals here:
http://fisherpaykelparts.net/index.php
Posted on Dec 11, 2008
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
How can I find a repair manual for my Fisher paykel GWL11 washer. I want to replace the controller, but owner's manual contains no parts listing or diagrams.
Careful! Fisher Paykel does not warrant their parts for even 1 day! I received a "new" control board from them once which did not work. Their comment to me was " It worked fine when it left here". That was the last F&P repair I ever did.
Apr 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
I am installing a new engine air filter on my 2008 Toyota Avalon and am having difficulty getting the air filter compartment properly seated after putting the new air filter in place. I unlocked three...
Toyota doesn't publish instructions for that. Its checked and installed for free as a courtesy on an oil and filter replacement, at good repair shops. You took it apart, I'm sure you can figure it out. People that aren't auto mechanics, think everything's so simple.
Dec 23, 2010 | 2008 Toyota Avalon
The lid is locked on my kenmore oasis washer
Unplug the washer first. How to open the service lid. Latches are approx 4" in from corners in front (where the little crack is below the lid) insert a putty knife, pushing in on the latches and pull up as it gives. Hold onto the side you've released and pop the oter side and lift up.
Now you will be able to see the lid lock; center front from underneath. Use a 1/4" nutdriver and remove the latch.
Now as far as I know, pn:8563937 was replaced with: W10059230 Bought mine from www.midwestapplianceparts.com.
Install is simple; 3 screws (1/4") behind the back panel will allow you to access the plug. Just feed the old one out and the new one in.
Jul 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Fisher paykel washer won't go into rinse cycle. Stops and gives steady beeping tone
http://www.docstoc.com/docs/25379677/Fisher-and-Paykel-Circuit-Diagram-GWL11
www.fisherpaykelparts.net/partmanuals/GWL11US.pdf - United States Above is a circuit, and a service manual, below are two DIY Washer help sites, to help troubleshoot and repair, the service manual has all troubleshooting and repair instructions.
http://www.washerhelp.co.uk/diy-repair-help.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Jun 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Replace acer 2410 travel mate back cover and new
Replacement of the upper lid is fairly easy and straight forward. I am giving you a link to the service manual that shows everything you need to replace the unit.
http://tim.id.au/laptops/acer/aspire%202920%202920z%202420.pdf
Jan 11, 2010 | Computers & Internet
Lid switch not working on GW608U washing machine
Tossed the bloody thing out and bought a new one. Surefire way to effect a repair.
Oct 08, 2009 | Fisher and Paykel Washing Machines
Dishwashers Logo
183 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
