I have a jvc flat screen TV it worked perfect before I put it in storage for a little over a month and I got it out today and I turned it on and the green light on the TV came on but no picture just a black screen thought it might be cold so I waited bout an hour and I tried again and the same thing just a black screen
    Top Expert:
  • Televison & ... Master
  • 35,671 Answers
The power supply may have failed while your TV was in storage. The green light merely indicates line voltage is getting to the TV.
Posted on Mar 20, 2014
  • Courtney Wisecup
    Courtney Wisecup Mar 20, 2014
    How would I know if that is wat it was and how to fix it
  • 5 Answers
SOURCE: rolling picture
If your Television is not warrantied, there should be rca, vga, and dvi connections you can use with your pc and video card. Since I am in usa I have know idea what freeview, skybox, or scart are.
Posted on Dec 15, 2006
SOURCE: losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Posted on Aug 12, 2007
skotkolr
  • 558 Answers
SOURCE: JVC LT-23X475 flat screen TV
capacitors are most likely to blame here, there are several that most likely are on the power board and are blown if you get them replaced the tv will function normally, the heat can come from the transformer since it is not getting smooth power from the capacitors. it is working very hard to dump the spikes in the electricity. I ups backup power supply rated for the tv's wattage will help smooth power and protect your investment.
Posted on May 27, 2008
SOURCE: Philips Flat Screen TV has sound but no picture
My Philips 50" Flat screen has sound but no picture. What should I do?
Posted on Feb 25, 2010
  • 453 Answers
SOURCE: Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Posted on Apr 14, 2010
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
My jvc 46' flat screen tv wont turn on anymore is its clicks like its turning on the the little blue light just blinks. nothing comes on the tv why?
Tries the tv unplug,replug the tv back an hour later,let the tv reset itself back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | JVC Televison & Video
32'' flatscreen (CRT) JVC I'Art tv will not turn on
I remember Jvc put out a service document about changing 2 transistors in the power supply..they are surface mount on the solder side of the pcb. You might not find the parts anymore unless your very tech saavy. Sorry man..
Jul 22, 2017 | JVC Televison & Video
The power went out today and now the tv is stuck on the JVC Digital Television screen. How do I get it work again?
check the software version. It's in the TV Menu. It it is not F108 or higher, you should call JVC to get the updated version.
Apr 14, 2009 | JVC LT-32E478 TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
Green Swooping Band on Top Of Screen JVC- 56WP74
Your convergence chip, or chips are gone. Easy to replace on this TV via front access panel. Remove the front speaker panel open up the access port and remove the front board. Get the IC's online and solder them in and replace, Make sure to check all of the resistors as they also blow and replace as needed. Make sure to use a good thermal paste like MX2 as this is the baser problem as to why these fail (you will see what I mean when you remove the chips)
Dec 17, 2008 | JVC AV-56WP74 56" Rear Projection...
Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Dec 10, 2008 | JVC LT-26X575 26 in. LCD HDTV
Protron LCD TV
Try resetting the ee-prom in sub menu
Sep 30, 2008 | Televison & Video
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
