Question about Konica Minolta Office Equipment & Supplies
Bizhub C252 error
On the finisher the exit trays are stuck. They will not slide down. It appears that someone removed them. When they tried to put the trays back in they got stuck and still have about a foot to go down but they won't move. How do I get these trays to seat properly?
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam,
Did someone leave a trash can or boxes under the output trays?To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them
RECOMMEND A TECH!!!!!
Posted on Jun 24, 2016
  • 12 Answers
SOURCE: Can not make bizhub c252 scanning trough e-mail feature
HELLO,
to use scan to mail to Bizhub c252 you have to set by web interface:
go to:
NETWORK settings --> EMAIL SETTINGS --> SMTP and set
- administrator email address
- machine email address
- smtp address ( autentication if request).
you should verify also the tcp-ip parameters:
ip,subnet,gateway, dns1, dns2 should be set ok.
bye.
Posted on Jan 18, 2008
SOURCE: renolio
your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Mar 30, 2008
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
taminol
  • 62 Answers
SOURCE: BizHub C252 - error Code C-2555 (Malfunction Detected)
C-2555 relates to a low toner density in the yellow imaging unit. I'm sure your daughter pressing buttons did not cause it.
I suggest you release the yellow imaging unit (the bottow row of units)
Just realease and pull it out a little way. Then switch the machine on with the door open. It won't start, but will ask you to shut the front door. Reseat the yellow imaging unit and shut the door. The machine should go in to a stabilization mode and then work.
However, if it comes back, I suspect a new yellow imaging unit will be required.
Posted on Feb 07, 2009
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
How do I clear the error code C11A3?
Shutter unit defection.Press Utility key-Meter count-Check details-00000000-End and you entering in service mode,select trouble reset.The very simple method is remove the finisher/exit unit and work without.
Aug 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error c252
no such code for bizhub c252
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
ERROR CODE C 1183
Some hit the exit trays? Ore did some one leave some boxes under the exit trays or trash can. Have to remove the rear cover of the finishing unit and reset the Elevation motor assy.
Jan 30, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub Konica Minolta c352 c-1183
Elevation drive problem for the finisher exit trays. Requires removing the rear finisher cover remove the elevation drive motor assy. BE CAREFUL FREE FALLING TRAYS!!!!!!!!. Then reset the position on the trays to align to the exit sensors below the orange rollers and remount the motor assy. DO NOT STORE BOXES OR TRASH CANS UNDER THE TRAYS
Sep 19, 2013 | Minolta bizhub 200 All-In-One Printer
Error code c0211 in bizhub c252
c0211 = Manual tray rise decent error - check PC14 lift up sensor, M2PC tray 2 vertical transport motor and also the tray 2 control board
Aug 15, 2013 | Konica Minolta bizhub Office Equipment &...
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
May 13, 2008 | Konica Minolta bizhub C250 All-In-One...
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
