Question about Polaroid Z340 3 X 4 inch Instant Digital Camera
I cannot close the battery compartment
The camera will not let me fully close the compartment after inserting the battery. This is an extreme problem because now i cannot charge nor use the brand new camera. please help. I need a solution asap
    Top Expert:
  • Polaroid Master
  • 6,702 Answers
Are you sure you did put in the battery correct and not the wrong way around? could be a mechanical block, to avoid damage to the camera, by wrongly placed battery.
Posted on Mar 21, 2014
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Batteries
Hi, This might be a case of the defective batteries (though brand new). Most if not all rechargeable batteries including Li-Ion batteries have only so much shelf life. The unit might be new but have been with the dealer for sometime. Probably your best bet would be to bring it back to the dealer and ask for a replacement camera or at least the batteries. Show him the fully charged indicator and how quick it will be gone when you try to take a pic. Of course, you would need your warranty card, proof of purchase and any other documents normally asked for complaints like this, Hope this give you an idea. Good luck and kind regards.
Posted on Aug 20, 2007
MarkDay
  • 111 Answers
SOURCE: New POLAROID i735--CARD ERROR
Fresh SD cards must be formatted before being used. Use the camera's menu options to format the card.
Posted on May 21, 2008
BillB-SA
  • 2761 Answers
SOURCE: I can't get my t1031 digital camera to turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Posted on Nov 28, 2009
  • 11967 Answers
SOURCE: My battery is fully charged but the camera will
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 01, 2010
HOW DO YOU CHANGE THE BATTERIES CXC3173
Open the battery compartment.
Take out the old battery
Insert the new battery
Close the battery compartment door.
For further information, look in the manual
Oct 11, 2017 | Cameras
Changing batteries
Without a make and model, nobody can answer your question accurately.
Dec 05, 2016 | Cameras
How do I change the battery
Purchase a replacement battery. Open the battery compartment. Remove the old battery, noting the positive and negative orientation. Insert the new battery in the same polarity. Close the battery compartment.
Nov 26, 2016 | Cameras
How do I replace the battery
  1. open battery compartment
  2. remove old battery
  3. insert new battery, observing polarity
  4. close battery compartment
Jul 26, 2016 | Cameras
My fujifilm finepix s8500 froze when i was taking a picture and now it wont turn on
Just to make sure nothing else is wrong. Please remove the batteries, charge them complete. After you replaced the batteries wait half a minute. Always close the battery latch fully. (there is a little switch checking if it is closed correct, to prevent writing to the memory, when the battery compartment is not closed correct.
About the batteries:
Your camera will work with AA batteries.
Always be sure the batteries are charged. Every one of them.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
success.
May 26, 2014 | Cameras
Fuji finepix does not start
Confirm that the battery is charged
Confirm that the battery is inserted facing the correct way
Confirm that the memory card/battery cover is fully closed
Dirty battery terminals reduce battery performance. Try cleaning the terminals with a cotton swab and reinserting the battery a few times.
Check if there is no debris or anything else in the battery compartment that can prevent correct contact between the battery terminals and the connection points in the camera.
Nov 19, 2013 | Canon PowerShot SX30 IS Digital Camera
Just replaced batteries camera is brand new and wont turn on
Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
Jul 18, 2010 | Canon PowerShot A490 Digital Camera
Compartment door will not shut properly, camera will come on
Drill 2 tiny holes, large enough to insert thin paper clip wire. One hole is drilled in the battery compartment door, close to the sidewall but in between the 2 adjacent batteries.
Drill second hole in battery case by first peeling back the ruberized coating slighty. This hole should be adjacent or sighted in line with the first hole. In each case, allow enough in tact plastic door or case so that it can withstand the pressure of a tightened piece of wire. Insert batteries. Then insert wire carefully tto penetrate both holes. Press down hard on battery compartment door and carefully twist the 2 ends of the inserted paper clip wire to secure the compartment door tightly. The one drawback is that each time you wish to change batteries, you will have to follow the above procedure.Don't know of any recalls on this condition.
Sy25 syfish@aol.com.
Nov 21, 2008 | Nikon Coolpix 990 Digital Camera
Polaroid Z340 3 X 4 inch Instant Digital Camera Logo
73 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
