Question about Samsung Office Equipment & Supplies
I have a samsung clx-3305, when i try to scan it says that the scaner is blocked can you tell me please how can i fix that
I scan some paper before but now it doesn't want to do it
    Habit-Forming:
  • Samsung Expert
  • 150 Answers
REPLACE CCD UNIT WITH CABLE
Posted on May 08, 2014
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Posted on Feb 07, 2008
dana_eng
  • 41 Answers
SOURCE: Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
Posted on Jan 17, 2009
  • 92 Answers
SOURCE: Samsung CLX 2160 "paperjam2" problem
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
  • Jam 0 indicates the paper failed to pass through the first sensor.
  • Jam 1 indicates the paper failed to pass through the second sensor and has jammed around the toner cartridge.
  • Jam 2 indicates the paper failed to pass through the second sensor and has jammed near the fuser.
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0 When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
  1. Power your printer off.
  2. Open the cover of your printer.
  3. Gently pull the paper toward you to remove it from the printer. Note: If you do not remove the paper slowly, you can damage the printer and the printer will require service.
  1. After removing the paper, make sure there is no additional paper in the paper path.
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1 When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2 When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
Posted on Jul 29, 2009
adibron
  • 83 Answers
SOURCE: samsung clx-2160 won't scan, it will print but
Hey paso!
It probably means that the scanner isn't configured well in the computer. What you should do, while to printer is turned on and connected to the computer is to go to the device manger (right click on "my computer" or "computer", and then go to the tab named "device manager"). go to "universal series bus controllers" and press on the plus sign. you should then have a list, search for "USB composite device" in that list. when you find it, right click on it and then left click on "uninstall" or "remove", approve it (press yes or OK) and after it done, disconnect the usb cable that connects the computer to the printer and restart the computer. only after the computer is booted up completely, you should reconnect the cable. after you do that you should get a pop up that says that new hardware is being installed (or something like that). wait for it to finish and after it says "you new hardware is installed and ready" (should appear near you computer clock), try to scan, it should work fine now. Good luck!
Posted on Dec 23, 2010
Testimonial: "thanks fast no super fast reply"
paulrandolfi
SOURCE: I have a Samsung CLX-3160FN, and after every page
Check paper setting paper over 80g should be set to thick.
Posted on Feb 03, 2013
How do you reset chip for transfer belt Samsung 3300
Reset counter in service Tech Mode:
[Menu] [Back] [Left] [Right] [OK] [Stop] [Menu]
Data Setup - Clear Count (enter password - 1934) - Transfer Belt
Reset toner count you can here:
http://fix-bay.com/fix-proshivka-samsung-clx-3300-3302-3303-3304-3305-clx-3305w-3307w-skachat-v12/
Nov 25, 2015 | Samsung Office Equipment & Supplies
DoIneed o replace all 4 my tner cartrdges
Hi... No, you don't have to. Use the control panel or driver software to check the levels of each cartridge. Then only replace the one that is empty.
Here is Printer Management software that can help you to get the status and ink levels of your printer:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_HK_EN&CttFileID=5928279&CDCttType=SW&ModelType=N&ModelName=CLX-3305W&VPath=SW/201412/20141223104106567/EPM_V1.05.66.00.exe
Here is a link to the user manual for you:
http://downloadcenter.samsung.com/content/UM/201501/20150112184228345/EN/english.pdf
And the link to the home page of your device if that can help: CLX 3305W SAMSUNG Hong Kong
Hope this helps...
Feb 01, 2015 | Samsung CLX 3305
It says replace a waste toner
The waste toner box is full.You have to replace it now.Replace the waste toner box with the new one or empty the waste toner box and fix it again.Your problem will be solved!
Apr 09, 2014 | Samsung CLX 3305 - multifunction fax /...
Copy/scaining problem
because there may be no page (or no page detected) in those 2 dark inches.
Feb 17, 2014 | Samsung CLX 3305 - multifunction fax /...
C406 connection problem
Yes Go To Googl Pl*** store download updated driver i would recommend going to printer and Setting But my briain Does not search for that printer is it discontinued? all i see is cartridges (i Nead more info)that is a toner # ) Printers Fr That Toner Is )CLP-360, CLP-365, CLP-365W, CLX-3300, CLX-3305, CLX-3305FN, CLX-3305FW, CLX-3305W; Xpress: C410FW, C410W, hope it helps Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Samsung Computers & Internet
How can I replace waste tonertank? (CLX 3305FN)
Hi, the waste toner tank is located on the left side when you open the front door. Just add some soap detergent and run under the tap water. You will able to use again after drying.
Dec 14, 2013 | Samsung CLX 3305 - multifunction fax /...
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Scan unit open or paperjam 2 message in Samsung CLX- 3185w
Please close the top cover (is just above the paper exit area)
Jan 31, 2013 | Samsung Office Equipment & Supplies
Jan 15, 2009 | Samsung CLX 3160fn All-In-One Printer
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
