Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
My fan is not working....just hums.
My window unit fan quit working last night and now it just hums. Is this something that can be fixed?
  • 614 Answers
Getting into window unit is tricky. The motors go out quite often. Might be capacitor. But you have weigh wether it cost more to fix than replace. Rus
Posted on Jun 14, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I have a ceiling fan with lights, last night the fan was turned on for the first time since summer, the remote is over the light switch. The remote to turn on the lights is used normally. Since turning...
There is a small relay in the ceiling fan causing this noise, try turning off all power to the ceiling fan and allow it to set for a couple of minutes. Turn it back on and see if it goes away. If it does great. if not, it may not be worth the repair cost but it can be fix by an appliance tech.
Dec 22, 2010 | Hunter Heating & Cooling
Whirlpool quit working - can hear short buzzing and fan
you might want to try a 3in1 starter kit for the compressor,you can get it from your local appliance parts store,it has instuctions on it,it is easy to do-mike
Feb 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
My whole house fan froze up last night..it hums
Call a professional it sounds like your squirrel cage fan has lost a bearing or broken a support component.
Jul 08, 2009 | Dryers
Dryer only hums when I turn the knob.
Something has seized the motor. It could be something in the blower(pen pencil, golf tee, you'd be surprised what can get in there). It could also be a seized bearing on the motor. There are electrical things that could have those symptoms but I would check the mechanical ones first. Let me know what you find.
Eric
Jun 10, 2009 | Dryers
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
511 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
