Question about Kodak Ngenuity 9090 Db - Document Scanner - External - 90ppm -
Feed hopper wont rise up no error
Scanner tries to start but hopper doesnt rise
    New Friend:
  • 31 Answers
Please contact Kodak Service & Support - 1-800-822-1414. This problem requires field support.
Posted on Apr 15, 2014
Hi,please help me my machine showing error e00025-003 cannon ir5050
E000 the heater fails to heat
E001 there is an abnormal rise in temperature
E002 there is an error in the rise in temperature
E003 there is an error in the rise in temperature
E004 there is an error in the IH power supply/IH control mechanism
E005 there is no fixing web/there is an error in the detection of web solenoid connection
E010 there is a feed motor error
E012 there is a drum motor error
E013 the waste toner pipe is clogged
E014 there is a fixing motor error
E020 there is no toner in the developing assembly; there is an error in the detection of
developing assembly toner sensor connection; there is an error in the detection of
developing hopper toner sensor connection
E025 there is an error in the detection of toner feed motor over-current, there is an error in the
detection of toner bottle motor over-current, there is an error in the detection of toner
bottle motor connection
E032 the counter of the NE controller has malfunctioned
E061 there is a potential control error/there is an APC error
E100 there is a BD error
E110 there is a polygon motor error
E121 there is a controller cooling error
E196 the EEPROM is faulty
E202 there is an HP error
E225 there is an error in the intensity of light
E227 there is an error in the power supply (24 V)
E240 there is an error in the communication between the main controller PCB and the DC
controller PCB
Jul 12, 2015 | Cannon Office Equipment & Supplies
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
Error e14 canon mp250
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Aug 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
Jul 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code E020
You can reset the code by getting into service mode.
Make sure there is toner in the hopper
*4*
scroll to TONER START
press OK
and wait for the machine to stop (about 6 mins)
if the error comes back and there is toner in the hopper maybe the toner feed motor is not turning
Also check the connecters on the dev tank.
Try these first any problems get back to me
Feb 26, 2008 | Canon NP 6050 Copier
PIXMA MP150 => it says E-2-3... Please HELP!!
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer: CANNON Printers MP150/MP160 ERROR CODE E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
Oct 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Kodak Ngenuity 9090 Db - Document Scanner - External - 90ppm - Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
