Question about AT&T Blackberry Curve 8300 Smartphone
My camera or video app doesn't work - AT&T Blackberry Curve 8300 Smartphone
    Sergeant:
  • 322 Answers
Try reformatting it.
Posted on Jun 14, 2009
How do I use my SD card for internal storage?
There are a quite a few options.
  1. Open Terminal Emulator and check with the 'df' command, how much space is left on your partitions. Is /data or /system full?
  2. Goto system/apps/all > 'Sort by size to' find out which apps eat
    up the most space.
  3. Check if you have big size apps installed where you could change data location within the app to sdcard. Thinking of navigation apps and games. Every app where you have to download additional data to the actual app.
  4. Make sure you use the sdcard for media like photos (camera settings) music and video.
  5. CM has a built-in system to move apps to SD under settings/apps/on sdcard. Check apps that are big and you use rarely and are not interactive first. Reason: If you still use the USB feature those moved apps are not available to system anymore and are least likely to cause trouble.
  6. Another option is to use the app Foldermount. Use it to move certain locations to SD like the Download folder. Or the DCIM folder if the camera doesn't support sdcard location in settings.
  7. Use the app Link2SD which is able to move every bit from an app (including app data) to SD. It has a good overview on how much space an app really needs. You will have to create a separate partition on the SD card for that to work.
Mar 20, 2015 | Tablets & eReaders
Webcam not work in omegle
There should be a pop-up asking you to either allow or deny access to your webcam & mic
Oct 18, 2013 | Toshiba Computers & Internet
Camera stopped working? !?!
Have you checked the app you are using has the 'Enable Camera' setting ticked in it's settings? Soz if that sounds silly but you'd be suprised how many 'setting's decide to change themselves for no reason.
Make sure you have enough free memory on the phone. Move as many personal files such as music and saved videos etc. from phone memory to the Ext. SD Card (external sd card)
Can you take pictures or video with the camera? If so the problem is with the video call app you are using (skype etc) uninstall it (remove the app) and reinstall from app store.
Did you notice the problem started after installing another app?? Installation of another app might be interfering with it also. Try video call after re-boot before opening up any other apps.
May 29, 2013 | Samsung Galaxy Note 10.1"
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
Nov 28, 2017 | Tablets & eReaders
We were filming using the video camera mode on the Kodak EasyShare MD41 and it froze half way through the video when we played it back. Now it has completely frozen and the power button wont work. None of...
Here is an online manual for your camera:
http://support.en.kodak.com/app/answers/detail/a_id/19200/~/kodak-easyshare-md41-digital-camera%E2%A0%E2%80%94%E2%A0extended-user-guide/selected/true
You camera does have a battery and it is possible it simply needs to be recharged.
Jul 26, 2011 | Cameras
How to take a video recording in my apple iphone 8gb
When you open the camera application, on the bottom right you will see a little slider bar with a video camera choice and a still camera choice. Keep in mind, I believe this is only available on 3GS or iPhone 4...if you have an iPhone 3G I don't think it will work with the standard camera app.
There is an app I believe called Qik video that you could download which would allow you to do video on an iPhone 3G
Mar 30, 2011 | Apple iPhone Smartphone
Iphone 4.2.1 model MB489X 8G can it video or can I get app to allow it to video
You should be able to do videos w/ Iphone 4. Go into camera app, and on bottom of app is small icon on bottom right corner slide small lever from camera icon to video camera icon.
Feb 23, 2011 | iPhone Apps
Iphone is the ultimate entertainment gadget. Which apps are recommended?
Well, there are just so many good entertainment apps for apple iphone. Here are some cool apps for you: 1.Pocket Guitar -laying guitar doesn
Sep 06, 2010 | iPhone Apps
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
