Question about MP3 Rocket
Looking for web plugin for mp3 rocket
Want to add my stream to mp3 rocket
I went and updated mp3 rocket like i normally do and after i finish installing the newest version i went to play the song in my itunes and the songs can not be located this has never happened before with...
I always turn off the add my songs to itunes, and i always move the songs to a sorting folder until i retag all the metadata before moving the songs to folders for each genre and then each artist etc. Nothing ever gets lost. Later i can add to itunes library or SAM Audio Broadcaster library (a disc jocky software). You never know if the mp3 rocket folder may be deleted during an uninstall and update. Also you can turn on a add to my itunes library upon download in the settings.
Oct 23, 2013 | MP3 Rocket
Cannot get on gmail nor on mozilla firefox. get something called ask.com. something called mp3 rocket is stuck on screen even though I put it in recycling bin.
try to uninstall your mp3 rocket.. go to control panel --> add remove files -- > mp3 rocket --> remove or uninstall .. thats it .. hope it helps
Aug 22, 2011 | Mozilla Firefox
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
Unable to access jarfile lib\MP3Rocket.jar
the error refers to a missing mp3rocket.jar file within the installation of mp3 rocket. i.e. C:\program files\mp3 rocket\lib. solution is: uninstall mp3 rocket and uninstall all versions of java and JRE from add and remove programs(XP) then restart. install a new version mp3 rocket and you will be prompted to download java again. once installed MP3 Rocket.exe should be restored
May 22, 2010 | Rocket ET300 MP3 Player
I can't run my mp3 rocket because mp3 rocket got block by fyrewall.please help me
There were two ways how to unblock mp3 rocket so that it will work, it's either you will totally turn off the fire wall of your computer but I don't recommend this because it's risky or you will just Except the software from being blocked by the firewall. If you select the latter you can easily follow the procedure:
>>Control Panel >>Network Connections>>Local Area Connection >>[Right Click] Properties >>Advance >>Setting >>[Menu] Exceptions >>Programs and Services
Please check if the program is there then uncheck it. If not there then add the program by hitting the add button and look for it in your system. Follow instructions and apply it then click OK.
Mar 08, 2010 | Network Computing Devices (NSH800S/A)...
How can I downlaod music onto my ipod nano from
Get the mp3 files from the rocket (drag and drop) into your MY Music folder. Then use iTunes and <File> <add folder(s)> to add the folders to the iTunes list, then sync your iPod.
Nov 18, 2009 | Apple iPod nano MP3 Player
I cant add music
there is a program called mp3 rocket if you look it up on google. download the newest version and try that.
Jul 11, 2009 | Creative Labs Muvo V100 MP3 Player
Mp3 rocket will not open. i have tried to uninstall and install it again and again. as soon as i finish downloading it, i check the launch now, and it will not launch. i try to open it from the icon and...
Sounds like yu have a Java conflict - go to your control panel, Add/Remove files and delete the last Java Update(especially Number 18) - that should fix it
Jun 08, 2009 | Rocket ET300 MP3 Player
How do i put music onto my mp3 video player
To do this you will need the software that came along with the player.
Like for Ipod you get itunes.
Install that software & plug the player when you are prompted.
Then it will detect the player.
And then select the tracks which you want to transfer to your player.
It will be done.
Mp3 rocket is a software to download the music.
I've never used mp3 rocket to transfer before but if you have all your songs in a folder you can go to itunes and click on File and add folder to library.
Then you look for the folder with all your mp3 files and click on it and select OK.
Hope it helps.
If you want the instructions in sing the itunes i can give.
Just ask me.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Audio Players & Recorders
Downloading music
The easiest way to do it is to use windows media player...open up your windows media player and it F3 then add all your files to your library,,,then hit the sync tab..drag the songs your want to add to your mp3 player under the sync list...then just hit sync when you finish
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
19 people viewed this question
Top MP3 Rocket Computers & Internet Experts
Ann Moroz
Ann Moroz
Are you a MP3 Rocket Computer and Internet Expert? Answer questions, earn points and help others
