Question about Robot Coupe Food Mixers
Can a reset button be replacedon a R2U Ultra robocooupe? Model #005500
Machine will not turn on. Reset button is broken
  • 87 Answers
I can not see the machine if reset button broken? it can be replaced if it is a fuse-able button ,
Posted on Apr 01, 2014
My Artisan KSM150PS won't turn on. Is there a reset button? If so where is it located?
There is no reset button. UNPLUG THE MIXER Remove the back cover and look for a broken wire, commonly one of the bottom two on either side. If none found you will need to use a multi meter and test circuits. If the machine has done a fair amount of work then check your carbon brushes, one under each black round side cap. Brushes are keyed on one corner, the motor will not run if you put one in the wrong way, you can look in the hole with a torch to see which corner is blocked.
Nov 25, 2016 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
My Kitchenaid '09 12C has light on, but no action. All parts click into place appropriately. No reset on base.
If nothing is working then it is your control switch. Pretty easy to replace and get. Cant remember the site name but if you put in your Kitchenaid model name and serial number it will pull up the site for replacement parts.
Aug 11, 2014 | Food Mixers
Won't turn on
Check for broken wire under back cover, check carbon brushed under black screw covers on sides. The brushes are keyed and only work one way.
Jan 03, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
I have Butterfly brand mixer grinder from India. While operating it went off due to overload, but it's not working now. I tried pressing the reset button but still no use. Now, I opened the machine and...
I have the same problem with Butterfly Ivory Plus mixer in India.... The mixer went off with over load. I pressed the reset button, but still the mixer wont start. Looks like a common prob with butterfly mixers.
Nov 02, 2010 | Food Mixers
The lever to start the machine the one that moves to the right to select the speeds won't move
Are you sure the bowl is locked into place? If it is, also check the safety mechanism that the bowl moves in order for the mixer to turn on to ensure that it isn't broken and is moving as the mixer won't turn on if the bowl isn't turning off this safety feature which is probably broken if the mixer start arm won't move.
Benjamin
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Spare beater
http://www.marbeck.com/mixers_kitchenaid_parts.html
heres link for replacement parts
my recommendations i would go with new parts but some will like to do the work them selves
Jun 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
WILL NOT RUN (KSM90WW)
theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
May 01, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Apr 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
108 people viewed this question
Top Robot Coupe Food Mixers Experts
eyecam
Ravi
Mister Danger
Are you a Robot Coupe Food Mixer Expert? Answer questions, earn points and help others
