Question about Lisle Pneumatic Oxygen Sensor Remover 43900
P2237 & P2243 oxygen sensor 2007 Kia Spectra EX 2.0L"
Need to change
Forgot to give my car details in my question about the meaning of fault code P2243. its a 2005 skoda octavia 1.6 petrol
Fault code P2243 means that oxygen sensor seems to be faulty. This is generic OBDII-fault code. If possible vag-com or compatible fault reader could give more detailed information and also live-data from the sensor.
https://www.engine-codes.com/p2243.html
Sep 06, 2017 | Skoda Cars & Trucks
P2237 code
code p2237 refers to heated oxygen sensor(HOS2) 1 bank 1-positivecurrent control-open circuit ---or oxygen sensor(O2S)1 bank 1-open circuit--- or heated oxygen sensor1 bank 1 -no signal=== causes for all three is wiring--HOS2----wiring O2S---wiring--HO2S---ecm. Basically I would be looking for a disconnected wire or broken wire to the sensors.
Jul 23, 2013 | Cars & Trucks
2007 kia spectra ex sedan
the airbag light is on, it telling you that there have a problem on your airbag system, such as simple wiring issue with a sensor, or it could be as bad as an abs module. it need to be plugged into a OBD2 code scanner/reader to know exactly what part triggered the code.
Aug 17, 2012 | Kia Cars & Trucks
2007 Kia Spectra 2.0 need to change timming beat or does it have a timming chain?
Hi.
The spectra uses a timing belt. The recommended interval to change is every 60K miles.
Here the spare part: 2007 Kia Spectra Timing Belt.
Regards.
Ginko
Sep 06, 2011 | 2007 Kia Spectra LX Sedan
My 2005 kia spectra has the check engine light on and its coming up with these codes can u tell me what they are?? p2237 p2243 p0030 p0140 p0171...
I have a 2005 Kia Spectra. The check engine light has been on and i got it checked. What does engine codes P0030 and P2237 mean?
May 22, 2011 | Kia Spectra Cars & Trucks
Kia spectra diagram for knock sensor
What do you mean the colors of the wires when the oxygen sensitive type NTK NO. (39210 - 23700)
Which means : signal,heater +,heater - , ....
the clor wire is :BLACK.WHITE,GREY,YELLOW AND BLUU
THANKS
May 31, 2010 | 2003 Kia Spectra
P0170 Troubleshooting code for 2007 Kia spectra ex. What does this mean and how to fix?
It is a fuel trim malfuntion.
P0170 Fuel Trim Malfunction - Bank 1.
Most of the time a simple fuel filter change will fix the problem.
You will need to clear the code with a jumper.
http://www.troublecodes.net/Kia/
DO NOT disconnect the battery for 20 seconds or you will have to recode your alarm and radio.
Kelly
Mar 11, 2010 | 2007 Kia Spectra LX Sedan
Lisle Pneumatic Oxygen Sensor Remover 43900 Logo
113 people viewed this question
Top Lisle Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Lisle Air Tool and Compressor Expert? Answer questions, earn points and help others
