Question about Lisle Pneumatic Oxygen Sensor Remover 43900
Changing oxygen sensors on Spectra
Two oxygen sensors are out, is it easy to change?
I have a 2009 oyota matrix turns over fine but wont start
code p 2238 refers to heated oxygen sensor(HO2S) 1 bank 1 positive current control --circuit low===causes --wiring short to ground --HO2S
also refers to oxygen sensor (O2) 1 bank 1 -positive current control --circuit ;ow==causes --wiring short to ground ---O2S
also refers to heated oxygen sensor 1 bank 1 ---implausible signal===causes --wiring short to positive, short to ground --HO2S---ECM
at this point I suggest changing the heated oxygen sensor in bank 1 exhaust before the cat converter using the specialist tool as the sensor wires are delicate and subject to easy damage
Feb 15, 2017 | Cars & Trucks
How to replace the oxygen sensor
There are two sensors, one on the exhaust manifold the other on the catalytic converter. The exhaust manifold is the easy one to replace, the other the car needs to be on a lift.
Changing the O2 sensor will improve you gas mileage,
Jul 01, 2014 | 1999 Saturn SL
Error code that says lean fuel. Injectors were checked and everything was ok. However, code continues to come on. Could this be an oxygen sensor problem? Also, transmission went out and was rebuilt. ...
Yes the airflow meter is very easy, it is in the air intake hose to the engine from the air cleaner. Boy those Japanese car makers really take you to the cleaners on repairs, that repair on a GM car would have been 1/2 that amount.
Jul 20, 2017 | 2000 Lexus ES 300
How do you change an o2 sensor on the 2004 dodge sprinter
There will be more than one oxygen sensor. They are located in the exhause manifold, and just after the catalytic converter. Changing them is very easy. You will need an oxygen sensor socket (available at part stores for around $10). Then the sensors just unscrew and screw in.
Nov 27, 2010 | 2004 Dodge Sprinter
Engine codes are 12, 51,21,53,55 can someone tell me what these codes are. engine is running extremely rich.
12 is battery has been disconnected recently, or went dead.
51 is Oxygen sensor stuck on lean mixture reading
21- no change in oxygen sensor reading
53- internal problem with logic module
55- is end of message/codes.
51 & 21, basically telling you same thing, but I wouldn't jump at changing oxygen sensor first, as a bad M.A.P. sensor can cause a rich mixture, thus oxygen sensor switches to lean to try and compensate. Personally, I'd go with map sensor first, check connections and vacuum lines if all good, replace it, then I'd go to oxygen sensor .
Oct 21, 2010 | 1993 Dodge Caravan
My engine light only comes on sometimes. I took to get inspected today and it read code P0133. What is this and how am I going to pay to get this fixed?
PO133 indicates that your front oxygen sensor is not controlling the engine properly .. thats usually a bad oxygen sensor .... in some cars thats easy to change. you could do it if you have any mechanical abilities .. in other cars its nearly impossible, it takes special tools and patients beyond human .. hopefully yours is one of the easy ones .. the part itself might be less than a hundred bucks at an auto parts store but more than that at a dealership . other things that can cause this ... if the wires going to the oxygen sensor are damaged .. and if there is a significant exhaust leak (you should hear that) .. usually changing the oxygen sensor will fix the problem ..it has wires going to it and it screws into the exhaust system somewhere between the engine and the catalytic converter. if you give your auto parts store the make, model, year and engine size of your car then they can probably show you where to find the sensor .. if you are not mechanically inclined then find a mechanic with a good reputation forget lowest price .. i find that often the auto parts store can recommend someone if you ask ..
Jul 03, 2010 | Cars & Trucks
Kia spectra diagram for knock sensor
What do you mean the colors of the wires when the oxygen sensitive type NTK NO. (39210 - 23700)
Which means : signal,heater +,heater - , ....
the clor wire is :BLACK.WHITE,GREY,YELLOW AND BLUU
THANKS
May 31, 2010 | 2003 Kia Spectra
How do you change the oxygen sensor on a 2003
buy the right tool to do it its easy just make sure you know which one you are changing bank1 or baank 2
Jan 25, 2010 | 2003 Chevrolet Suburban 1500
Locating and replacing the o2 sensor on a 2005 kia spectra
a wrench and just unplug the sensor wire and screw out and install new one. they make a special socket but i just use a wrench.
Sep 11, 2008 | 2005 Kia Spectra
Lisle Pneumatic Oxygen Sensor Remover 43900 Logo
61 people viewed this question
Top Lisle Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Lisle Air Tool and Compressor Expert? Answer questions, earn points and help others
