Question about Maytag Legacy Top Load Washer
Maytag doesnt agitate. it overfills. wont automatically change cyles. bounces everywhere
Hey I have a Maytag PAV2300AWW and the first problem was the unit overflowed. So I tried blowing in the hose in the top panel and nothing.. Then, it started working again ( the water would turn off when it was supposed to) but you have to change the cycles manually and the machine will not agitate???
  • Dustin Jones
    Dustin Jones Mar 20, 2014
    And how do you tell if the pressure switch or " level switch" is bad??
  • Maytag Master
  • 15,557 Answers
With what you are describing, there is a busted or loose spring that holds the drum in the washer. When it breaks it can disconnect the water level sensor and so the machine does not know when it is full. Drain the machine and unhook it and lay it down and look underneath from the bottom for broken springs or shock absorbers. They can become broken from washing large loads when the machine spins and is off balance. Then you need to locate the water sensor and it can be a tube that runs along side the drum. IT may have come loose electrically or physically. You can also access the drum by prying up on the top of the machines main housing but you have to be careful not to damage the paint.
Posted on Mar 20, 2014
  • Dustin Jones
    Would that also make the cycling only work if you turn the knob manually? And would it still spin but not agitate? thx for the tip
  • Brad Brown Mar 24, 2014
    If there was enough weight off balance that caused the tub to be off center from breaking or stretching any shocks or bumpers, the damage might have also affected the controls, wires or sensors. You need to have a meter to test them.
SOURCE: Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Posted on Mar 07, 2008
SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Posted on Aug 29, 2008
onthejob5130
  • 640 Answers
SOURCE: wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Posted on Jan 18, 2009
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
  • 76 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Jan 31, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Pav2300aww
Washer overfills with water even when changing the level setting.
Dec 11, 2007 | Maytag PAV2300 Top Load Washer
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
