Question about Rancilio Silvia Espresso Machine
Low steam pressure
Switch Steam ON. Orange light comes on. Wait for orange light to turn off. Barely enough steam to froth milk. Silvia is 7 years old. Any suggestions?
  • 29 Answers
Agree with previous suggestions. Steam wand is either blocked with stale milk or maybe even a piece of limescale is stuck in it. Generally it will block in the most awkward place to clear ie. where the pipe bends. So try clear it with a pipe cleaner or a piece of thin wire. If the boiler has limescale in it, clearing the bockage is a short term fix it will probably block again. So descale the machine also. Im not sure how effective vinegar is on lime, I would take the boiler apart, clean any loose deposits and then descale it using a packet of Everpure Scalekleen and hot water. Hope this helps so please inform of progress, if any.
Posted on Mar 20, 2014
  • 9,742 Answers
Descale the heating elements with vinnegar.
JetJedi221
  • 25 Answers
SOURCE: steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Posted on Jan 08, 2008
SOURCE: Rancillio Silvia Steaming problem
Have you tried descaling it?
Posted on Aug 18, 2008
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
  • 1089 Answers
SOURCE: MY SILVIA NOT WARMING THE WATER
Hi
If your lucky.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Posted on Dec 23, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Posted on Jan 27, 2010
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
Not enough steam is produced to make good froth.
I have one too and what I do is: turn all 3 switches on and while I'm waiting for the "ready" light to come on I go ahead and pour the milk into my frothing pitcher and prep my espresso basket.
After the "ready" light comes on I install my espresso basket and turn the handle to the "left" so no liquid starts coming out.
Next, I take an empty coffee cup and hold it under the steam nozzle and start opening the steam valve until I get only steam instead of a stream of hot water. Once you have steam, close the valve, put your pitcher of milk under the steamer and froth as usual to around 150 degrees.
Jan 21, 2010 | Coffee Makers & Espresso Machines
Miele CVA615
miele's parts are available direct through them only
Sep 22, 2009 | Miele CVA615 Espresso Machine
Steam does not come out of steam pipe
If you wait too long after making the coffee, you will not have enough water left to make steam. Try to steam the milk immediatels after the coffee loses pressure.
Jan 16, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Steam problem
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
142 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
