I need a replacement for my Sunbeam/Black Steel 480W Power Supply made by casegears, seems its been dis-continued. Is there a compatible replacement?
When we replaced a monitor and opened computer to remove dust we noticed exposed wires, appears to have overheated. The RED wire connected to the cd drive
  • 39 Answers
Http://www.newegg.com/Product/Product.aspx?Item=N82E16817709010 This is the closest replacement. Ensure the diamentions are the same and it will work fine.
Posted on Apr 22, 2014
antiochpc
  • 1314 Answers
SOURCE: replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
  • 10 Answers
SOURCE: I have a ASE380-UD440A PC. I need Pwr Supply wiring diagram.
It should follow the standard AT or ATX convention try this site
http://pinouts.ru/Power/
click on power supply connectors
Posted on Mar 14, 2009
  • 263 Answers
SOURCE: emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Posted on Jul 30, 2009
  • 54 Answers
SOURCE: Green power supply light blinking? HP Pavilion a820n
These wires vary based on the type of the board each wire lead is labeled to coorespond with the pins on the board. You need to reference the manual for your specific motherboard. If you don't have the original get it from the vendor support site or just google it. Unless your motherboard is an odd brand it should be easy to find.
Posted on Sep 10, 2009
  • 6 Answers
SOURCE: gateway dx4640 wont come on.
Change CMOS battery and clean the RAM memory slot and chip
Posted on May 23, 2010
I need a replacement Sunbeam/Black Steel 480W Power Supply made by casegears
If it's a standard ATX case, then any power supply is compatible.
equal or higher power output is fine.
so a 500w will still only use the power needed by the hardware.
Mar 20, 2014 | Dell Inspiron 518 Desktop Computer
Power button on dell 5000 flashing amber
***I'm pretty sure your power supply is dead, you will either #1 take to repair shop or #2 replace it yourself.
The Best Value 550W Gold PSU 12cm 24-Pin 550 PSU is compatible.
The Corsair Memory 550W VX PSU is compatible and Corsair is an excellent brand, but you may have an issue locating the excess power connectors inside the case.
The Xilence XP480-12R Power 480W Quiet PSU would be fine, providiing the "hard drive connectors:2', are 4-pin Molex connectors.
Aug 04, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Pavilion a1320n won't boot-no power to mother board. replaced power supply- now won't boot if plug to mother board is seated tightly-if you pull it part of the way out or jiggle it-it will boot. plan to...
Check my guide created for such an ocasion, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Seems like you may have a slightly loose connection, that is between the mainboard and the solder of those 20pins on the mainboad.
Try pushing it in tight, it should clip in, as there is a clip on the one side on the 20pinblock. Then once it is clipped in pull it slightly, without releasing the clip.
This will ensure that the 20pins will make contact with the mainboard.
The other solution to this problem is to check the solder points of these 20pins.
Another is that the mainboard may be damaged, therefore needing replacing.
Take care!
damnor01
Apr 21, 2011 | HP Pavilion a1320n (882780261747) PC...
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
I want to install a gts 250 graphic card on my pc this card want a 8 pin wire and my power hasnt it there is a reduction which want 2 (6 pin) wire and my power has just one 6 pin wire can i use my...
No, if you attempt that then your computer with either not work because of video card errors, or it will boot up and run for a couple hours and then the graphics card will most likely melt due to insufficient power to the fan. Your best bet is to return the video card and buy a video card that is compatible, or buy a new power supply with the connections that you require.
Jan 13, 2011 | Intel Power 480W 480 Watt Pentium 4/ AMD...
Does the T2893 have to have an ATX power supply specifically for the emachine? I tried to upgrade to logisys 480w supply and the fans and a few lights come on, but the unit won't boot up.
there are TWO different power cables on the new machines. (not just two parts to the ATX)
one is the ATX like you are used to.
The other is a small four-prong plug (coming off of the power supply - look for yellow and black wires) find the matching receptacle on the motherboard.
good luck
Oct 20, 2009 | E-Machines T2893 PC Desktop
Schematics or diagram for a 480W PSU
I need a schemetic diagrm D15-1013/diablo ATX 250w Power supply
Thanks Louie.
Dec 18, 2008 | Computers & Internet
I have a Sunbeam Gas Grill Mod. # HG4659EP. I need new wheels amd nuts to go on the axel. I think the parts needed are part # 30220113-two wheels and part # 00400251 - two hub caps . I need a local dealer...
I don't think Sunbeam are still selling their products, but do continue to supply spares to cover their warranty.
Try their website
www.sunbeambbqs.com.au
Or the contact numbers on their warranty page.
Click HERE
Failing that, there may be other makes of wheels that would replace yours, you just need the dimensions, and probably dome covered star-lok festeners. The axles should not need replacing.
Jul 09, 2008 | Thermos Stainless Steel Gas Grill
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
