Question about Refrigerators
Amana model sx25sw noise
My Amana model sx25sw (purchased in 1997) , side-by-side refrigerator is making a noise and I am not sure if it is the motor or the compressor. I cleaned the dust from underneath and the back and front but it is still making the noise. Is there a way to diagnose this (the sound is similar to a helicopter)?
    Sergeant:
  • 361 Answers
It sounds like the fan is hitting the carboard shrowed it is made from paper and is probably colapseing that is the only thing that tuns on a fridge it is an electric fan
Posted on Mar 20, 2014
  • Jackie Panico Mar 24, 2014
    Turned out to ve the condenser fan motor. Fixed and quiet now. Thanks.
SOURCE: Buzzing intermittent
could be a relay failing, a long 2 -3 seconds hard electrical hum could be the compressor failing & the relay overload is doing it's job shutting down your overheating compressor, unplug it for 30 min plug it back in a slight hum & click off is most likely just a relay but a long hard electrical hum is bad news Compressor & if it has no warranty left on the compressor repair could run $500.00- $700.00.
Posted on Dec 21, 2008
peyton32034
  • 410 Answers
SOURCE: Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Posted on Dec 15, 2007
SOURCE: Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Posted on Oct 19, 2006
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: light is on, fan runs, compressor will not come on
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Posted on Mar 19, 2009
ICE MAKER NOT WORKING
Ice makers can be purchased inexpensively on ebay for about 45 dollars.
Otherwise the hassle can be caused by the solenoids feeding the unit water, the icemaker thermostat, heater element, cam motor, cam sequence, icemaker "off" switch, etc. Also check to make sure that the water line feeding refrigerator is working!
Nov 22, 2013 | Amana Side-By-Side Refrigerator 26 cu. ft....
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Amana side by side refrigerator freezer making grinding noise but stops when door is open
make sure that it is level,does it rock some if so adjust the levels on the bottom of it
Mar 21, 2012 | Amana 25.6 cu. ft. Side-By-Side...
Noise after the motor starts
Is this a clicking or a knock/pop sound? The knock knock sound can sometimes be helped a little bit by tilting the refrigerant filter drier (located in the compressor compartment) to a horizontal position. Ask your technician to do this for you.
May 29, 2010 | Amana DRS2462B Side by Side Refrigerator
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Freezer not getting lower than -20deg
Three things bad defrost time bad defrost termination switch or bad heaters. You need aservice tech to check this out. Russ
Jul 19, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana sx25sw - side by side - fridge not cooling
might be as simple as bad defrost timer( 10530703 $50)and/ or defrost thermostat(R0161088 $35), replace em both for under a hundred bucks. the timer is found behind the kickplate lower right hand side and the derfost thermo is wired in behind the rear panel atop the evaporator, and yea your right its preventing flow cause you "self-defrost" isnot functioning.Great frig though Id fix it
Nov 04, 2008 | Whirlpool GS6NBEXR Side by Side...
Amana refrigerator not cooling
you may have a bad defrost thermostat .. it is on the evapator check it with a ohm meter and see if its open..
let me know
Jun 17, 2008 | Amana SXD524VW Side by Side Refrigerator
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
