Question about Samsung HW-D450 Sound Bar
Sound bar Will power off when I turn off tv but I have to manually turn on sound bar when I turn tv back on, is there a way to set it up so it turns on and off with the tv power
  • Joe sidoti
    Joe sidoti Mar 20, 2014
    It's the samsung hw-f550 soundshare
    Genius:
  • Samsung Master
  • 1,054 Answers
There should be an "auto power" feature that should turn the unit back on once a signal is detected.
Posted on Mar 20, 2014
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
Why does soundboard turn off when connected with Bluetooth. Samsung TV is mounted on wall so I do not want to connect sound bar with wires going up the wall. Thanks
Your sound bar will turn off when there is no audio signal applied. So when your TV is off the soundbar will turn off. You will need to turn the sound bar back on when you turn on the TV
May 26, 2016 | Samsung Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
How do I connect a sound bar
I used a optical cable to connect my sound bar to the TV. You will need find out what audio outputs you have available - look at back of TV set, and use proper cable to make the connection between the TV audio output and the sound bar.
Also your manual that you receive with the sound bar may help also.
If no manual available go online to the manufacture of the sound bar and check out the manual there.
Also TV manual should point out the locations of audio outputs and the types that available.
Feb 28, 2015 | Televison & Video
Set tv pcm output
is it flipping back to Auto setting without you turn off the tv or unplug it ?
http://www.tvrepair.localdomain.me/
Jan 07, 2014 | Toshiba Televison & Video
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
I have a Coby TFTV4028 and just bought a sound bar which only works when on the TV input but is not recognized on any other inputs. Is there a way to fix it?
The only audio output I see is the headphone jack from which to run the sound bar input. Is the sound bar surround/expanded sound features? Check the audio setup menu on Tv, the sound bar input selection, and try a cord from the headphone jack to the sound bar, if you haven't already. There should always be 2 channel stereo at the head jack unless it's turned off in tv menus. I see the owner's manual is very poor.
Oct 26, 2017 | Coby 40 TFTV4028 LCD TV
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Samsung HW-D450 Sound Bar Logo
236 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
