Among the Barons AR test answers
I dont know the answers and i fail the test
2 Suggested Answers
  • 6982 Answers
SOURCE: Failed 3 tests with emissions
Clean up your mass air flow sensor and check the map sensor...both can mess with ignition/fuel settings. Neither may be out of range enough to give you any performance problem but together they can do that. If you are going to add race fuel, it may also help to add 3oz of acetone per ten gallons of fuel. It vaporizes faster than gasoline and burns cleaner. It will also clean your injectors. A slight egr malfunction can also throw off readings but will not show up as a problem unless it becomes worse, but usually shows up as an idle problem first.
Posted on Jul 17, 2009
How do i get ar tests answers for free
What sort of printer is an AR.
If it is not a printer then why use this form of media?
Sep 09, 2014 | Office Equipment & Supplies
How can i tell if my fuel pump is bad?
old post, but Ill answer this , as it seems most forums give bad advice. on this topic.
answer,. read the FSM , or alldata.com or suzuki pit stop plus
it shows 6 tests.
this car came with 2 diff. engines, G16b and J18.
and the tests are simular but data is different.
here are the tests in the FSM.
1: cranking pressure. 35 to 40 psi. this is a guess. no engine stated, so no real numbers... answered. only a guess.
2: running pressure (vac. drops it) drop about 6PSI running.
we now test the FPregular for proper reg. at 3 vacuum points. (a hand vacuum tool)
3: the shut test.
4: the leak down test.
5: the 4 tests for INJECTOR leak down tests. 1 by 1>
its really 8 tests.
now the shade tree test
fuel dont leak from rail, fitting cracked, cranking , pump dead
or lost 12vdc to pump cranking.
that be it, with no gauge. must DIY fail here if the fitting dribbles.
as dribble tests dont tell you if pressure is correct.
a carb can run on 0.1psi or gravity , only
but on EFI it takes, 28psi, min. (injectors makers rule , no mine)
Jun 25, 2014 | 2002 Suzuki Esteem
BLINKING H 4 AND ALL BUTTONS DONT DO ANYTHING. LIKE IF IT'S LOCKED UP
In order press # * C * then enter the number 14 then 1 and press start.
Please let me know if this fixes your problem it should, no one answers.
99 percent of the time this will clear that code.
Aug 11, 2010 | Sharp AR-M205 Black and White Copier
I dont have any cheats on my ar on my ds but when
when u start ur ar hold down ab and start and select at the same time in till it gets to the ar menu then it should work i would write this down in case it happens again
Jul 04, 2009 | Datel Action Replay for Nintendo DS
Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Jul 01, 2009 | Sharp AR 163 Copier
Simplicity 3416H BARONS
simple answer . no
Oct 02, 2008 | Garden
Sound card
Dont pay the Geek Squad robber barons a dime...it is easy to put in a sound card.
shut down your computer, unplug it, take out the screws holding one (usually the left) side on, take it off, GROUND YOURSELF!!!. it is then a simple matter of finding a slot for it to fit in (you may have to take a rail of the back of the case for the slot) plug it in securely, close up your case, plug it back in, then follow instructions that came with the card for installing drivers and such....
May 24, 2008 | Dell Computers & Internet
82 people viewed this question
jasbo
jasbo
