Question about Eagle Cuda 242 Fishfinder
Powers on but screen is blank
New batteries etc tried to hard reset still nothing. checked all the connections they are good. all it does is beep
My acer wnt start up or boot is bios missing dll blue screen is all i ger
If you have a boot menu the problem is likely not the Bios. No beep codes? Some PC's will give hardware error codes in the form of long and short beeps through the MB speaker. Otherwise a bad boot sector on the hard drive would likely give you an error message, like ; NTLDR is missing
Press Ctrl+Alt+Del to restart
Check the power and ribbon wire connections to the hard drive. If you have recovery disc/'s, doesnt hurt to try! Otherwise its a new operating system, new hard drive, and searching for drivers. Good luck to you!
Aug 13, 2014 | Acer Aspire 7540G Compatible Laptop Power...
As soon as the power supply was connected and switched on, the motherboard would power up and the fans would spin.. all hard drives/optical drives etc would turn on. But there was no post, or beeps, just a...
Sounds like you have a short in your display plug or the display itself.You also should try different or new ram sticks to eliminate ram as the cause.Try an external monitor also to see if there is any video showing.Technicians seem to always say the motherboard is bad to get the most money when the motherboard most of the time isn't bad its whats connected to it(ram,display,cd/dvd drives etc.
Jul 01, 2010 | Acer Aspire 3000 Notebook
BLANK SCREEN HP DV 9000
Run system restore to factory default.
Start the system and hold down the f11 key till you hear a beep. Then follow the onscreen instructions.
Good luck.
Aug 23, 2009 | HP Pavilion dv9000z Notebook
I have HP pavilion DV6500 laptop. Last night, system suddenly struck while working and now only power light is okay, and some blue lights also runs which shows sounds etc...DVD is working, but no sound of...
Please do not panic....The first thing what we need to do is perform a hard reset...What does Hard Reset mean... Unplug the A/C Adapter Pin from the notebook...Turn the notebook upside down and then remove the battery from the notebook...Turn the notebook in the upright position and then press the power button for 30 seconds without the battery and without the A/C Adapter Pin connected to the notebook... After 30 seconds place the battery in the battery outlet and connect the A/C Adapter pin and restart the notebook...Check if you can see anything on the screen....If you can't see anything on the screen then please perform a forced shutdown by pressing the power button down until all the lights have turned off...Then as soon as you restart the notebook press the F10 key continously on the keyboard...It will take you to the BIOS Screen... Check if you see the screen...If the screen is still blank then don't perform the next step....Click N for No...Then press the F9 key and then select Y as in Yes...again press the F10 Key then press Y and it will boot to the desktop.... still you have the same problem then perform a recovery....If the screen is blank in the BIOS Menu then try connecting an External Monitor...If you cannot see anything on the screen it is a problem with your video card or monitor you will have to contact HP since your fan does not work...If you have any other queries please don't hesitate to contact me and i will help you with the same.....
Aug 18, 2009 | HP Computers & Internet
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem. If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Jun 27, 2009 | HP Pavilion zd7020US Notebook
I have a Myguide 3100. It has worked up until now but it powers up only shows the initial face page. Nothing then happens and the screen goes blank. I have tried it connected to my computer, charged u
i have the same thing happening to me. Every time im turning the sat nav drom ireland to UK it makes same beep noise and stays at ireland can you help me please
May 30, 2009 | MyGuide 3100 GPS Receiver
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Eagle Cuda 242 Fishfinder Logo
88 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
