Question about Freezers
My whirlpool fridge runs but does not freeze or cools either section could it be gas
It runs at the same level all the time instead of kicking in when the temp drops
  • 20 Answers
I would say that if there is absolutely no difference in temperature from the inside to the outside and the compressor is operating it would seem to be a loss of freon.
Posted on Mar 20, 2014
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
My whirlpool chest freezer runs but does not freeze?
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Fridge not cold
I had the same problem with fridge/freezer and repair man told me NOT to use anything that has been in freezer as what is happening is that it is constantly freezing and defrosting because there is not enough gas in the system to cool the appliance. It is possible to re-gas the appliance but service engineer advised me to claim a new fridge/freezer from company which I did. Please do NOT eat anything from freezer as could make you ill.
May 01, 2008 | Freezers
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
