Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
My icemaker in lower freezer came loose how do i fix samsung
The icemaker came loose from freezer top
  • Bob Butcher Mar 20, 2014
    Here is a photo looking up at the screws that hold it in place.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 34 Answers
There should be two screws holding the ice maker to the top of the freezer compartment. If those fell out, it would explain your problem.
Posted on Mar 20, 2014
Hi. I have rust on my sr-s27fta Samsung refrigerator and I'm trying to take down the door in order to fix it. Do you know how can I do that?? Thank you
There's a plastic cover on the top door hinge. Pop it off and remove the screws that fasten it to the top of the fridge. Pull it off and don't loose the washers on the hinge pin. Lift the door up off the lower hinge pin. If it's the freezer door, do the same but take off the lower toe guard grille to expose the water tube going to the water dispenser. Separate the hose at the in line connector at the bottom of the door before you lift the door up and off the hinge pin.
Mar 25, 2016 | Samsung Refrigerators
Tip
Samsung RB195ABWP/XAA got loose wire and not working since bought. Fixed loose...
<p>A common question on <b>FixYa.com</b> is about different <b>fan noises</b> that happen and the causes. These noises are often fairly easy to fix and some are the result of other problems.<br /> <p><br /> <p>If you are hearing a rattling noise or a squeaking, high pitched squeal coming from the bottom or back or the <b>refrigerator</b> then the <b>condenser fan motor</b> is probably going bad. Sometimes the bearing in the <b>fan motor</b> will even get so bad that the<b> fan blade</b> will start to hit anything that is close to it down there. This can create a very loud noise. This fan normally will be running when ever the compressor is running also.<br /> <p><br /> <p>As with any other problems you will want to get these things fixed promptly. If the problem is just a squeal a bit of light motor oil will do wonderful things for you. Many times though, you will have to order the parts needed to fix the problem. When repairing the problem make sure to remove all power the the unit and to wear gloves is possible, as there are many sharp edges in close quarters that will butcher you hands in no time.<br /> <p><br /> <p>The other fan that can cause noise is the <b>evaporator fan.</b> While this fan too can get worn and become noisy, it also can sometimes start to hit ice that is building up because of a problem with the defrost system of the refrigerator. Checkout my tips about <b>defrost problems</b> if you find a build up of ice and the fan is hitting the ice and making noise. This fan can also be oiled if needed, and it will also wear out and need to be replace occasionally. This fan usually will go off when the door is opened, so sometimes it makes it difficult to figure out exactly what is happening. By holding the door switch in manually, you can get the fan to run and troubleshoot it more easily. Make sure to remove all power before trying to service the fan. Spinning fan blades do not play nice with your hands!<br /> <p><br /> <p>For many refrigerators you will have to remove some covers or even the whole bottom of the freezer to get to this fan for replacement. Checking the exploded views at appliance parts websites can give you an idea of where the fan is located and what must be removed to get to it for replacement.<br /> <p><br /> <p>Both of these fans and the associated parts are available for most refrigerators online. Look for them at the appropriate spots in the exploded views of the units.<br /> <p><br /> <p><br /> <p><span>How to Buy </span><u><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online"><span>Appliance Parts Online</span></a></u>
on Apr 13, 2011 | Refrigerators
Freezer drower adustment?
The one time I had this problem, a warranty technician (on site for the icemaker again) opened the freezer drawer about half way and, I sh*t you not, slammed it shut and it was fixed. Somehow, this realigns the plastic parts on the two side tracks. Anyway, it made sense and it quit frosting up. Don't slam it too hard though, probably best to let the wife do it..
Jun 27, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My Samsung Space Icemaker makes ice very slowly. I keep hearing a click-click-click and maybe a few cubes come out. I have taken the white box inside the icemaker loose but not disconnected it. I think...
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
Sep 26, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
My icemaker stopped working
Check freezer temperature. Must be 12 degrees farenheit or lower.
Apr 15, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
My freezer degree keeps flashing and a beeping noise comes on about every minute and lasts for roughly 6 beeps. What is it?
Your icemaker sensor is out of its place. unplug the unit . check bottom of your icemake, the sensor looks like a little ***** , insert it back. turn unit on, and reset the board, Hold power freez, Power Cool for about 10 seconds.
Oct 27, 2009 | Samsung RB1955 Bottom Freezer Refrigerator
Kenmore freezer-on-top icemaker not getting water into icemaker. I replaced the water valve solenoid with a new one, but no change. There is no AC voltage at the solenoid terminals. The icemaker itself...
First check the temperature in the freezer to make sure it is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
If the temperature is ok then the ice maker mold thermostat needs to be replaced. And yes you can replace just the thermostat.
Aug 19, 2009 | Refrigerators
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
