Question about Schwinn Cycling
Ranger brakes I was replacing the innertube on my Schwinn Ranger, and one of the calipers on my front brake fell off. I was able to recover it as well as most of the bolts. I was not able to find the exterior nut, meaning that my brake-pad will no longer tighten or be fixed into place. Where can I get a replacement or substitute? TL;DR caliper thread missing! What do?
  • 20 Answers
I don't know your location, but here Lowes has specialty hardware. Also there are hardware specialist that can match what you lost if you have the other gender part. In my location there is a business "King Bolt" that is a hardware paradise.
Posted on Mar 20, 2014
  • 11 Answers
SOURCE: Where can I get replacement brake parts for 20
Any proper bicycle shop! They typically don't like to work on Wal Mart bikes but they can fix it.
Wal Mart buys inexpensive imports but there are probably lots of components to fix it with.
Posted on Jul 07, 2009
  • 1137 Answers
SOURCE: can't get my Schwinn front wheel into alignment.
The wheel and rim truing article at this site may help you:http://www.parktool.com/repair/byregion.asp?catid=56
Posted on Oct 27, 2009
2009ubuntu
  • 10 Answers
SOURCE: brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Posted on Jul 31, 2009
Coachphil
  • 347 Answers
SOURCE: the brake pads fell off
The brake pads only need to be lined up with the braking surface to work. As far as keeping the bolts in place I would suggest a drop of loctite (blue) on the threads of the bolts to keep the nuts in place.
Posted on Nov 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: hello! I need a manual for a 1988 schwinn world
The owner's manual won't talk about that.
http://www.schwinnbikes.com/support/owners-manuals
If it's Shimano, go to http://techdocs.shimano.com/techdocs/index.jsp and find it.
What's wrong with the brake? Usually pads wear out (replaceable) or adjustments are necessary. I've had bikes for over twenty years and never replaced a whole brake for failure.
Use a search engine for video answers. "replace bicycle front brake caliper", for example.
http://www.parktool.com/blog/repair-help/sidepull-brake-service
Posted on Jul 08, 2011
How do i replace front brake hoses on 94 ford ranger
Here is a good forum to find your answer.
http://www.fordrangerforum.com/exterior-tech/88010-brake-line-hose-replacement-94-xlt-2-dr.html
A few few things to remember: Purchase fresh new brake fluid and have a clean MityVac pump (both can be purchased through AutoZone, NAPA, Orielys, etc..) , plenty of clean rags, brake line clamps to stop the fluid from leaking when you initially pull the line off.
Be prepared to bleed ALL the brakes after changing the lines. When bleeding the brakes (after replacing the old lines) work from the caliper that is the longest distance from the brake master cylinder first to the shortest distance line.
Nov 22, 2014 | 1994 Ford Ranger Supercab
What solution is there for a siezed up right front brake on 1 1994 2wd ranger?
Knowing how to work on braking systems?
Education
My guess --replace a failed rubber flex hose
I don't know how much moisture & rust is in the system,
so is the caliper seized also
Jul 17, 2014 | 1994 Ford Ranger Supercab
Brake pedal almost goes floor
The washer there should be a plain copper washer. Check that when you tighten the hose up that it is not twisted up and working loose .
Mar 19, 2014 | 1997 Ford Ranger SuperCab
1998 ford ranger repair manual for the abs brake system
If the brakes work but you have to push very hard, try checking the vacuum supply to the brake booster with the engine running.
Oct 19, 2013 | 1998 Ford Ranger
What tools do I need for front brake replacement on a 93 v6 ford ranger two wheel drive?
I have honestly never replaced brakes on a Ford Ranger but front disc brake pads are fairly simple to R & R. You either need a large allen wrench or a socket and ratchet. The socket size is probably 14mm or 9/16. You can use the tire iron and jack for your spare to remove the lug nuts on the wheel and jack up the truck. You should really use a floor jack and jack stands. Either way keep your body and limbs out from under the truck. Usually there are 2 caliper pins or bolts to remove. pull off the caliper and use a "C" clamp to compress the caliper pistons into the caliper completely and do not use anything but a clamp or you will never get it to depress. Keep the old brake pad in there on the piston side as a buffer between the clamp and the piston and it will help evenly disperse the pressure on the piston. Lube up the pins before you install them or they will be a nightmare to get out again. Vent the system by loosening the cap on the master cylinder to make the piston easier to depress. Let me know if I can help any further. Please rate me on this answer.
Jun 08, 2010 | 1993 Ford Ranger SuperCab
I need to know the name of brake parts for a 1988 Ford Ranger. It's for the front brakes. Does anyone have a manual?
rotors,pads,calipers,brake hoses,brake lines,front brake hardware,wheel bearings and the races,grease seals i hope this helps you. richard
Apr 11, 2010 | 1988 Ford Ranger
How take off pins not bolts on caliper 87 Ford Ranger front brake
The pins / wedges just tap out use a scewdriver on the metal edge of the pin just tap it out to the rear and when putting them back in just tap them back in from the front. You will see they are diamond shape and metal cased around rubber very easy to do just take your time.
Nov 28, 2009 | 1987 Ford Ranger
1984 ford ranger 4x4 2.8l is pulling hard to left and front left wheel is smoking and locking up
Dear Smoking And Locking.......
It sure sounds to me like you are having a brake issue on the lf of your vehicle..Obviously your lf brake assembly is not releasing.You could have a seized caliper, a restricted lf brake hose, a restricted brake line, or pad material that is unsafe, it's time to get those brakes inspected ASAP!!!! Brake repairs on that year of vehicle are fairly simple for the first timer....if you need any more help just get back to me ...THX HOPE I COULD HELP!!
Nov 18, 2009 | 1984 Ford Ranger
1988 ford ranger. looks like front brake caliper are held on by what I can best describe as 'shims' how do I pull them out so I can change brake pads?
knock them through with a punch or screwdriver. there just a squareish type block with rubber in the middle.
Sep 16, 2009 | 1988 Ford Ranger
Front Passenger brakes rubbing
Dis brakes have residual pressure thar keeps the pads in constant contact with the roter.It is very light contact, so not to worry. If left is not in contact with rotor then chk it for loose wheel bearings.
Jun 09, 2009 | 1999 Ford Ranger SuperCab
Cycling Logo
131 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
