Question about Samsung LN-T4665F 46 in. LCD Television
Not getting a picture from a Samsung 46" LCD TV
I have a 2 year old Samsung 46" LCD TV that has worked great until recently. When I turn the TV on, I will have a clear picture for approximately 5-7 seconds, then it will go black. I still have the sound after the picture is black. When I attempt to turn it on again after several hours, I sometimes will get my picture back for a day or so. I've called Samsung and they could not help me. Any advice?
    New Friend:
  • 58 Answers
Check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
Posted on Jun 15, 2009
I have a 46" flat screen samsung TV which I bought
change your tv configuration channel type is probably cable instead of air
Nov 09, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
I have a 52" 1080p 120 Hz LCD HD Samsung TV that
You have a problem on your Power supply board, possibly a bad capacitor or loose connection. You can look hard at your power board and check for these things or replace it from places like shopjimmy.com or discount-merchant.com etc
Jan 19, 2011 | Samsung LN-T4671F 46 in. LCD Television
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
Have a 2 yr old 46" Sony LCD. No picture at start up.
It may just need time to warm up. Try starting it up and waiting around for the picture to show.
Jun 04, 2010 | Sony BRAVIA KDL-46WL140 46 in. LCD TV
TV screen went blank and it began clicking, turning itself on/off repeatedly. Had to unplug from wall to make it stop. TV is only 2 years old and has worked perfectly until now.
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
Nov 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
Whenpower is applied, TV clicks on and off, no picture.
there probably is ive had a similar problem i just opened mine up and replaced the power board fixed it but i dont at all recommend fixing your own tv take it to a pro :P
Aug 03, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
354 people viewed this question
Jerry Greenberg
Jerry Greenberg
