Question about Vizio L32 32 in. LCD HDTV
No response on plugging in.
I have a proscan plcd 2401a. when i plug it in it powers up and and then a box pops up saying '21.0' then another box pops up and says 'No programs are shown!' i get no response from the 4 urc's ive tried or from the panel buttons on the side.
  • 3 Answers
Check your wall socket or braker inpower box or look for reset button good luck
Posted on Mar 20, 2014
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
We just got a 50 inch LCD PLCD 5092 8b plasma TV the only thing that shows is a blue screen with proscan on it how do we get it to play
hi if its a new tv press menu button or settings on the remote and look for tuning & follow instructions :::::: good luck
Jul 26, 2015 | Proscan Televison & Video
Proscan 43LA45H powers up just no picture. hooked up another tv to cable box and no problems. what needs to be replaced
"Main Board" ~ it's the board where your cable, video player and everything else plugs up to. Part of the board has become defective. I would start right away finding a replacement. If I can assist you further please feel free to contact me.
Col. Dana Gillespie
Oct 06, 2014 | Proscan 42LA45H 42 in. LCD TV
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
Nov 29, 2013 | Proscan Televison & Video
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
My 16 year old son found a Proscan 19LB30QD on the side of the road (good old country living) anyway, it has not plugs, it is probably broke, but we thought we'd give it a try and see if it works. ...
Do you mean that the unit has no power cord or is the TV missing the input board from the side? Sears Parts Direct has parts for the Proscan 19LB30QD here: http://www.searspartsdirect.com/partsdirect/part-model/Proscan-Parts/Television-Parts/Model-19LB30QD/3027/0333300/50036238/00001?blt=06&prst=0&shdMod=19LB30QD . The AC cable is PART NUMBER: E080515H00 for $27. There is also an adapter, PART NUMBER: E075WDN1, for $26.79. The input board is part 6 on the diagram (main board).
Other cords will depend on what you want to connect to the TV. There is 1 HDMI port for connecting a set top box, component, composite and S-video jacks (for other set top boxes), a VGA port and a coaxial (antenna jack). Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/19678/PROSCAN-TV-VCR-or-DVD-Combo-L0807673?brand_name_search=fall+back .
I hope this helps.
Oct 06, 2011 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
42" PROSCAN LCD: THE BOARD BETWEEN THE PLUG WHERE POWER COMES IN & THE FIRST RESISTOR BURNT. DOES THE WHOLE BRD. NEED TO BE REPLACED OR CAN I REPLACE THE PLUG AND RESISTOR?
you can replace the plug and resistor but make sure you remove any carbon that may of happened,you should be able to scrape it off.if you dont have any luck repost with part number.
Sep 21, 2009 | Proscan 42LA45H 42 in. LCD TV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Pro Scan On / Off Switch Problem!
Sometimes a power surge or bump will cause the program chip to hang up. If there was no surge or bump, then program chip may be defective. Any case i would return it for another.
Mar 01, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
41 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
