Question about ZTE Score
If my phone is turning on but it is not working oh yea my phone is cracked very badly
Keeps turning off want work
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
You lost touch screen capabilities?? digitizer is gone..
Posted on Mar 20, 2014
LOW COMPRESSION PROBLEM
Low C can be many things, has it overheated? it can be leaking head gasket, burnt or worn out valves/guides or cracked rings. Check for smoke to help rule out the rings, short of an upper engine tear down, you won't know which, a basic leakdown test on the cylinder may help determine
Apr 15, 2014 | Reliance 91-1994 Saturn Sc Sc1 Sc2 Sl Sl1...
Bad power supply
big red
oh yeas these emachines have a bad power supply all you neet is to go to a local computer store and get a new one worked on mine
Oct 25, 2009 | E-Machines AC Adapter for eMachines M6410,...
Yea i have a 92 dodge Stealth, n im Curious
some different reasons.engines getting a little hot--.evaporation,small leak.small crack in a head, or radiator.check all hoses,to see if its leaking put something down park car on it let set over night, if its leaking youll see it.a tarp works well holds the fluid itll kill cats dogs they love anti freeze its sweet..
Oct 07, 2009 | 1995 Dodge Stealth
Fuel guage
sounds like a bad ground on the sending unit. hope ths helps mike
Jun 16, 2009 | 1999 Oldsmobile Cutlass
Sidekick 3 keeps locking up
Go to setting then go to system info....then press
Menu +shift+x
Then it will ask something...and press yes
Feb 02, 2009 | T-Mobile SidekickĀ® 3 Cellular Phone
2000 ford windstar, directionals both not working, hazards work f
turn signal flasher module or turn signal switch. I usuall try to wiggle teh column switch or move it slowly up and down, back and forth to help determine if it has a bad contact. if i cant get a failure (or turn signal) that way I begin the testing at the base of the column. the flasher module is a common failure on those and isnt unreasonably priced. if i had no diagnostic procedure i would try that first. oh yea, try turning the hazards on and off rapidly several times. the signal goes through the four way switch.
Dec 31, 2008 | 2000 Ford Windstar
Clicing noise when turning corners
drive shaft universals worn.check rubber boots ok with no splits or or leaking grease.If boots have split and dirt got in then change the ends only,but its possible to remove the end and by turning cage around extract the ball bearings,wash the lot out with diesel and fit a new boot and re pack with grease ---yes i know it could still knock a bit and fitting new yea yea but it might work and evan if their is a bit of noise on turn ignore it till it gets really bad as they could last another 100,000 kms
Nov 30, 2008 | 1998 Volkswagen Golf
Can hear a click at fuel pump but no humming..is it the fuel pump??
Was it a factory GM pump? Check for power at the Grey wire going into the pump it should have 12V for 2 seconds after you turn on the key so you cant do it by yourself get someone else to either turn on the key or watch the test light, If you have no fuel pressure but have 12V for 2-3 seconds then you have a bad pump and be sure to double check the Ground make sure its clean and secure also change the fuel filter at the same time. Forget the oil changes they do nothing for the car oh yea change it one every 4 or 5 years is way fiine but change the fuel filter EVERY EVERY 15,000 miles no matter what. If this information helps please give me a fixya rating.
Oh yea make sure you buy a Factory GM pump you'll be gald you did,
Sep 02, 2008 | 1990 Chevrolet S-10 Blazer
ZTE Score Logo
26 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
