Question about RCA Televison & Video
I have a 48 inch RCA LCD TV that I bought 16 months ago. There are 3 white dots (about the size of a quarter) vertically down the right center portion of my TV. Almost looks like there is a spotlight
Just started on the weekend. Won't go away. The 3 dots are slightly brighter than the rest of the screen.
    Master:
  • 397 Answers
These sound like pressure spots. Caused by pressure to the screen at some point. Often this requires the LCD panel to be replaced.
Posted on Mar 20, 2014
  • Joe McBride
    Joe McBride Mar 20, 2014
    Can pressure spots be cause by not touching it? They are too far away from each other and too big around for them to be from someone touching it. They are about the size of a quarter each, and are about 2 inches apart. Almost like a pattern. I also keep my PS3 behind my TV and near, but below, that spot. Not sure if that helps...
SOURCE:
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
Drummernick
  • 440 Answers
SOURCE: Black Vertical Stripe
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Posted on Feb 03, 2008
  • 8 Answers
SOURCE: LCD TV White Screen
do you still have this tv? what happens if you hit the info button - does it bring up the banner at the bottom of the screen?
Posted on Feb 12, 2008
SOURCE: blue dots on LCD screen
You will most likely need to replace the panel. You will have to contact Sony and they will send a Factory Trained Technician to your home to replace it. Since you are not on Factory Warranty this repair will cost you. You may find it cheaper just to replace the television.
Posted on Oct 12, 2008
  • 3 Answers
SOURCE: philips plasma tv vertical black stripe
Check these videos for repair instructions for black lines.
Just requires some soldering.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Feb 09, 2009
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
I just bought a 23 in. hp monitor and i can not get the picture to fit the screen. vertical is fine but the horizontal will not go over. there is about an inch of black on left and 2 or 3 on right side,...
it is a lcd or crt moniter specify that first
if its lcd check the resolution copatiblity of your video card
it may not match the resolution of the lcd
if it is crt then there will be a control panel setting on the monitor
Dec 26, 2009 | Computers & Internet
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Cable question
Make sure your refresh rate is set no more than 60HZ. Your monitor might not support refresh rates higher than that.Also try lower resolutions.
Here is a list of specs: (also try another cable)
Features/Specifications:
  • Olevia LT23HVX 23-inch HDTV Compatible Widescreen LCD TV
  • General Features:
  • Black cabinet
  • 23-inch active screen size
  • 16:9 widescreen aspect ratio
  • HDTV Compatible
  • 1366 x 768 native resolution
  • 1600:1 contrast ratio
  • 8 ms response time
  • 178° horizontal and vertical viewing angle
  • NTSC TV system support
  • 480i, 480p resolution support
  • Progressive scan
  • Color temperature adjustment
  • Built-in 5 watt x 2 speakers
  • PC resolution support up to 1024 x 768 @ 60Hz
  • English/French/Spanish language
  • Sleep Timer
  • V-Chip parental control
  • Energy Star compliant
  • Remote control included
  • Wall mountable
  • Front Panel Features:
  • IR sensor
  • Power
  • Menu
  • Channel down
  • Channel up
  • Volume +
  • Volume -
  • Source
  • Rear Panel Features:
  • 15-pin VGA
  • Audio in
  • Headphone
  • Component Y, Pb/Cb, Pr/Cr
  • Composite RCA video inputs
  • S-Video
  • Antenna
  • Power Specifications:
  • 100-240V, 50/60Hz, 2.5A (max)
  • 110 watts AC power consumption
  • Unit Dimensions:
  • 16.5 x 27.1 x 8.3-inches (H x W x D)
  • Gross Weight: 23 lbs
  • Net Weight: 21 lbs
  • Regulatory Approvals:
  • FCC
  • CSA
  • UL
Package Includes:
  • Quick Start Guide
  • Manual
  • Remote control w/two AA batteries
  • Power cord
Additional Information:
  • Notes
  • Model: LT23HVX
  • Product Requirements:
  • Satellite cable or antenna
  • PC with 15-pin VGA adapter
  • Stereo system with component, S-Video and composite jacks
  • Available power outlet
  • Disclosures:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 20-Inch to 23-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15mm (bright to bright dots)
  • Minimum distance between defects: 5mm (dark to dark dots)
  • Disclosures:
  • Consumer Notice:
  • This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Screen not centerd
If it is a RCA F27649 then it has what they call a bonded yoke, meaning the only adjustments to shift the picture horizontal or vertical are electronic adjustments via the service menu.
Feb 11, 2007 | RCA F27649 27" TV
Televison & Video Logo
99 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
