Question about Philips Magnavox Learning Universal Remote
Rc2542/01 need a steps follows auto programing
    Top Expert:
  • Philips Master
  • 74,185 Answers
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 20, 2014
How to reprogram keyless entry car alarm transmitter
you did not specify vehicle that fob represents but the following links should help you ------if the fob has auto start need to bring to dealer for reflash -----
Program remote key fob for your car simple and easy steps Need to Re Program Key Fob GM Ford Honda Right Here
May 28, 2016 | Cars & Trucks
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
I have a Intermatic self-adjusting wall switch timer and I can't program it even though I have followed the instructions 3 times.
Program 1 is ON, and program 2 is OFF, 3 is ON, and 4 is OFF, etc
Copy following link for EZ step-by-step programming for ST01C timer:
http://waterheatertimer.org/ST01C-program.html
Jun 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Why my dynex tv keep sayin no signal
Please follow the below troubleshooting steps and check the operation:
  1. Please check whether the connections are secure and proper.
  2. Connect the input device to a different port on the TV.
  3. Make sure that you have selected proper input.
  4. Connect the device using a different cable.
  5. Auto Program the TV if you have connected cable directly to view TV programs.
  6. Auto Program the Cable Box using the Remote supplied with it if you're trying to view channels using a Cable Box.
  7. Unplug the TV for more than 1 minute and then connect it back and check the operation.
I hope one of the above troubleshooting step will definitely resolve the issue.
Thanks for using Fixya.
Mar 27, 2012 | Dynex Televison & Video
How to install
Reeva,
If you have not tried to install it then follow the steps given below.
Disconnect the device from the computer. Insert the CD that came with the device into the drive. Let Auto run run the CD. Install the drivers for your device according to the operating system. Reboot the computer. Connect the device and allow Windows to auto detect it and load its drivers. Happy printing.
If you have attempted to install the device then go to Control Panel->Add Remove Programs. And uninstall the device and reboot the computer. Then you can follow the steps given above.
Aug 15, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I need to set digital channels on my Sony Trinitron system. It will not auto-program on digital on analog. model KD-27FS170
You need to switch the TV to digital mode before you run the auto-program. Press the "DIGITAL/ANALOG" button on your remote before you run the scan. After switching to digital mode please complete the following steps to run the auto-program:
1. Press the "MENU" button on the remote
2. Press the right arrow ">" button on the remote once to highlight "CH" (looks like 3 boxes)
3. Press the "+" button (in the center of the arrow keys) to select.
You will now be in the "Digital Channels" menu. If you are in a menu called "Channel Setup", you are in the wrong mode. You should exit the menu, press the "DIGITAL/ANALOG" button on your remote and start again at step 1.
4. Press the down arrow on the remote to highlight "AUTO PROGRAM"
5. Press the "+" button (in the center of the arrow keys) to select.
The auto program will now run. This could take a while to complete but a progress bar is displayed so you can see how far it has gone.
If you can't get this to work or need further assistance, please post back.
Regards,
BElectric
Dec 09, 2010 | Sony Televison & Video
Have purchased a curtis model kcr2614A under the counter kitchen player, cannot program TV, have an hd tv antenna, directions are difficult to understand for programming, I would appreciate assistance....
I have found a manual that may be better than you have now, it seems real easy to understand and has pictures too,basically you use the Volume + & - keys to step through the Menu, and there is an "Auto Search" function too..5.5.1.1 page 11, start there and follow pictures.. START: Press MENU Key to enter the menu list, press Left and Right Key to enter the following list, press Up and Down Key to enter the sub-list and then press Left and Right Key to setup the contents. 5.5.1.2. In the CATV state, choose Auto scan and press OK to enter Cable system settings. Four options, AUTO, STD, IRC, HRC can be chosen. 5.5.2. In the Start to scan item, press VOL+ to start searching. Auto searching will clear the primary program. 5.5.3. Press Auto Scan Add Ch will start auto search based on primary program.
You don't need to do all the extra bits like names etc, if you don't want... just use default settings.. Get the manual below... http://www.curtisint.com/html/CustService/Manuals/CUR_KCR2614A_EN.PDF
Mar 01, 2010 | Televison & Video
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
Philips Magnavox Learning Universal Remote Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
