Question about GE Profile WPRE6100G Top Load Washer
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Posted on Mar 20, 2014
  • Dayton Computer
    Dayton Computer Mar 20, 2014
    Exactly ther answer and solution makes sence.
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Posted on Oct 27, 2008
  • 530 Answers
SOURCE: Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Posted on Jan 04, 2009
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
j_alcaidinho
  • 107 Answers
SOURCE: My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Posted on Jan 13, 2010
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
Machine is not filling with water.
hi
the solution is so simple, you have to open it
and clean the plastic pipe that runs from the tub to the load switch, sometimes gets dirty with detergentes and mud.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
GE Profile WPRE6100G Top Load Washer Logo
129 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
