Question about Refrigerators
Frigidaire upright freezer not freezing display messed up
My Frigidaire upright freezer model LFFU14F5HW suddenly will not cool at all-the compressor and fan do not come on.The display on the front where you can adjust the temp only shows weird symbols instead of numbers-it has been like that for a week but now all of a sudden the freezer doesn't freeze at all.I have a freezer full of game meat that I really don't want to lose-please help! Oh,it is just a few weeks past the one year warranty.
  • Teresa Benner
    Teresa Benner Mar 20, 2014
    Thank you so much-I really appreciate you taking the time to answer my question.
  • Refrigerators Master
  • 15,639 Answers
Unplug it and let it sit a minute and then plug it back in. If this does not work then you need to do some more testing to see if it is the control board or panel or wiring harness.
Posted on Mar 19, 2014
Testimonial: "Thank you so much-I really appreciate you taking the time to answer my question."
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 25 Answers
SOURCE: frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Posted on Jul 03, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
  • 531 Answers
SOURCE: Refrigerator stopped freezing & cooling
can you hear compressor working
Posted on Apr 05, 2009
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
Frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Jan 01, 2012 | Frigidaire Freezers
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a Frigidaire ffu1466gw0 Upright Freezer. It is a frost free freezer and doesn't seem to be cooling properly. Some items seem to be solid enought, but ice cream is melted for the most part. I have...
if the compressor is running, the fan beside the compressor and the fan in the freezer should both be running, dirty coils can cause a problem. frost buildup on back of freezer wall is indicative of defrost problem.
Jul 26, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
FRIGIDAIRE UPRIGHT FREEZER COMPRESSOR VERY HOT
Well I finally found the screws for the front grill. The compressor started cooling off once the seal was put back in place. So I'm going to give that a day or so. Still did not find the coils I'm assuming that they are in the sides. One thing I do know for sure, is that I'm putting you guys in my favorites. I educated myself so much from your website. I'm not sure I ever had a problem except the seal. I don't have the original motor to check but I'm working on getting it back. If I would have found this website before the tech I would have saved $150.00. Thank you so much.
Jul 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
