Question about Nikon Coolpix 5600 Digital Camera
PNY memory card doesn't work in my nikon coolpix 5600 camera
The PNY memory card gives me a "This card doesn't work" message. How do I format the card
SOURCE:
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 390 Answers
SOURCE: Nikon Coolpix 5600 can't upload to PC
I need to know the log appearing before I can assist. Many issues can cause cameras not to upload. Is this a sudden problem, ie, have you uploaded before successfully to your pc? Pc issues will also stop you. Let's do this step by step ans start with the log thta appears. Let me know.
Posted on Aug 10, 2007
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
SOURCE: Bought a new memory card for my nikon coolpix 3100 card wont work
It is too big. 1G is max for the 3100.
Posted on Oct 16, 2009
How do I get the SDGC 8GB memory card to work for my Nikon s4100 coolpix camera?
You may need to format the card prior to first use. This should be in the menu system somewhere. Your manual should point you in the right direction.
Jan 09, 2016 | Nikon COOLPIX S4100 14 MP Digital Camera...
PNY Memory Card
Most cameras have a menu go there and look for a red or green word FORMAT and push it it will erase everything make sure you exported your pictures first.
Mar 19, 2014 | Nikon COOLPIX S200 Digital Camera
Camera does not recogonize a memory card?
Make sure you're using SD cards, not SDHC cards. SD cards max out a 2GB. If your cards are larger than 2GB then they will not work in the 5600.
Mar 18, 2012 | Nikon Coolpix 5600 Digital Camera
I use some new alkaline batteries but the camera (Nikon 5600 coolpix) doesn't go on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 11, 2011 | Nikon Coolpix 5600 Digital Camera
Camera goes through format routine,but card but
The 4500 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is not electronically compatible with the camera. You'll have to restrict yourself to SD cards 2GB and smaller.
Jun 28, 2010 | Nikon Coolpix 4500 Digital Camera
My Nikon oolpix 5600 will not allow me to format my cards or take pictures. It displays "memory card is write protected". I know my daughter dropped it but everything else is working properly.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2009 | Nikon Coolpix 5600 Digital Camera
How do i delete all pictures from memory card for
you can format the card or look for a delete all option in the menu settings
Here is a link you can copy and paste in your internet address bar to view your owners manual:
www.evergreen.edu/media/ml/pdfs/p_nikoncoolpix.pdf -
Oct 01, 2009 | Nikon Coolpix 5600 Digital Camera
CoolPix 5000 "OUT OF MEMORY" message that we can't figure out
At 4GB size, your memory card is likely a SDHC card, and not a standard SD card. Although they look the same, there is a difference in formatting. Unfortunately your model camera was designed before the SDHC format came out, and it will not work with your camera. But fortunately standard SD cards are very inexpensive these days, and you should be able to purchase a good 2GB standard card for around $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=sd+card+2gb&x=23&y=20
Jul 03, 2009 | Nikon Coolpix 5600 Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
Memory card not working
the card is probably too big . try a 2 gb .. some cameras cant take higher capacity cards
Mar 23, 2009 | Nikon Coolpix S560 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
146 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
