Question about Cell Phones
Cannot change a quanity item
Want to change #4 of clear to #2
2 Suggested Answers
  • 4 Answers
SOURCE: We purchased a Kitchen Island today Modle Number
You can call Dorel's customer service at 1-800-295-1980. I'm sure they can help you with the missing parts.
Posted on Feb 18, 2010
Samsung 4521f print fax received in memory
Changing the Fax Setup options:
1 Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear.
Read More..FAQs Mono Multi function Receive fax for SCX 4521F
and Tech Support Printer
Jun 27, 2014 | HP Office Equipment & Supplies
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
Does not always clear soap , no increase in quanity ,and does not always spin clothes dry ??
The easiest solution to this problem is a sock or other small item has passed out of the washer and is clogging the filter of your water pump. Open the front panel and look at the water pump. If there is a round access door next to this pump, then spread some large towels out to catch excess water then turn the cover of this access door to remove it. Look inside and pull out the stockings/socks/pencils/coins etc that are stuck in there.
This is a 10 minute fix and if you find something big in that trap, 99% chance your problem is solved.
Feb 02, 2011 | Kenmore Elite 45986 Front Load Washer
Oil quanity
Should be 4 1/2 quarts. If you are changing it yourself add 4 quarts then after a minute or two check it. If it's between the quart low and full line. start the car, then let it sit a few minutes and check it again. If your changing the oil filter the oil will fill up the filter when you start it therefore the level will go down.
Thank you and good luck,
Lee
Oct 12, 2010 | 1998 Ford Escort
2000 volkswagon beetle. The a/c cuts off after driving the vehicle for a few minutes. power, ground, and fan control module good. ?????????
If all those items are good then you have to test the following items :Low pressure switch , compressor clutch and refrigerant quanity,pressure and restriction free circulation (any icing on the lines).
Jul 20, 2010 | 2000 Volkswagen Beetle
Freezer has stopped keeping items frozen. Constant alarm. No door seal problems. No recent large quanity of warm food inserted into freezer.
Either flap in vent that controls the air flow or the freon is low or compressor and coils are filthy and dusty
Nov 08, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
For a honda 125 cbr how often do I change the oil and what type does it need?
oil change: every 1000km
oil type: silkolene comp 4 10w/30
quanity oil: 1000mls
Nov 03, 2009 | 2005 Honda CBR 125 R
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
I have a DTC P0301 w/pending code P0405. Old. Sillhouette. 2000 model year. 3.4l E engine. Approx 140,000 mi. I have a series of questions related to this vehicle. With in previous 6 mos., 25...
try swapping #1 injector with another injector to see if the code jumps to another cylinder. maybe possible that the injector maybe clogged cause a misfire code. best to change with one in the front. dont know what p0405 is off hand. is it an evap code? try swapping the injectors first the clear the code and see what comes back
Aug 13, 2009 | 2000 Oldsmobile Silhouette
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
