Question about Samsung SyncMaster P2250 22 inch LCD Monitor
Does anyone know how to disassemble a Samsung sync master p2250 22 inch? last night it smelled lime burnt Plastik and I want to take a look, but there are no screws ot smth. like that....
The samsung screen p2250 does not have screws whitch I can undo. so the screen might be glued together?! how can I take it aprt?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 210 Answers
It uses internal plastic clips to hold the halves together. Gently pry the edges apart until you find a clip. While holding the edges apart, release the clip. You'll find about 12 of these clips hidden internally. Good luck.
Posted on Mar 20, 2014
samuelseno
  • 103 Answers
SOURCE: Cant detect 1600 x 900 on control panel - display
You need to install the driver for your samsung sync master 2033, so the the graphics will improve or updated.
Posted on Jun 04, 2010
budmrtn
  • 11361 Answers
SOURCE: how to unlock the adjustment
http://www.fixya.com/support/r4616564-samsung_lcd_monitors_lock_unlock
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 27, 2011
waterppk
  • 42 Answers
SOURCE: samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
Posted on Jun 04, 2008
  • 225 Answers
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
Posted on May 28, 2009
  • 36 Answers
SOURCE: samsung sync master 740n have power no display can
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
Burnt wire smell Board Flashing Br
The unit was running when we came in. No Storms in the area. it was blowing hot air, but was still on the cool setting. There was a burnt wire smell coming from the unit. And the diag. code was Br. I found this odd since it still had power.
Aug 16, 2014 | Amana PTH153B50AM Air Conditioner
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
Whirlpool GD5SHA XLTO2 problems. Last night, awoke to a sort of burnt plastic smell coming from refrigerator. Turned off ice maker and smell stopped coming out. Today, freezer was not keeping things...
sounds as if your overload relay, controlling your compressor has burnt out heres a part number that should getyou back in working order( complete with intructions pn# 8201786
Jun 15, 2009 | Whirlpool GD5SHAX Side by Side...
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Saving music on my micro sd..
try and reformat the card then try again......make sure the files are .jpg,.jpeg,.gif etc and the music is .mp3
Feb 26, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Can i use limewire?
step 1; down load songs from lime wire. step 2; go to lime wires library, and about half way down the page there is a button called explore. click on it. step 3; open windows media player, and click sync. a list should show up, step 4; click on songs on shared folder, and drag to sync list. step 5; connect sandisk, and click synk to e 250 on upper right hand corner area, and wait for sandisk to write! hope this helped!
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Samsung SyncMaster P2250 22 inch LCD Monitor Logo
215 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
