Question about GE Refrigerators
Refrigerator is freezing food and liquids with the controls set to their lowest setting.
Model Gss25LGMA WW
  • GE Master
  • 4,655 Answers
This could be caused by a defective=> WR60X10052 Damper Control Assembly or could be caused by a defective fresh food thermister=> WR55X10027 Thermistor or WR55X10027 Thermistor. You will need to run the diagnostics found in the GSS25LGMA Service Manual I am here should you need me, Thanks John Tripp Appliance 911
Posted on Mar 20, 2014
2 Suggested Answers
  • 220 Answers
SOURCE: GE GSS25LGMA WW FREEZES FOOD
These refrigerator use the cold air from the freezer the cool the refrigerator. At the rear of the upper refrigerator compartment, there is a shroud. Remove the shroud and you should see a "flapper" that shuts off the cold air when desired. You will most likely see the flap is broken. Once the flap is broken, you lose control of your refrigerator temp. This is a common problem with this refrigerator.
Hope this helps.
Posted on Jan 11, 2009
My food freezes even on the lowest setting. What is the problem?
This has to do with the temperature control, or cold control as they may call it, in the refrigerator. This is located in the refrigerator part of the machine. Write down the model and serial number wich is located in the refrigerator, and contact a parts distributor, I use apdepot, and ask for a cold control, or fresh food thermostat. This will fix your problems, good luck!!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 08, 2010 | Whirlpool Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Refrigerator freezes food regardless of dial setting. Control board?
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Feb 04, 2010 | Kenmore 52642 / 52644 / 52649 Side by Side...
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Jan 16, 2010 | Frigidaire FRS26H5AS Side by Side...
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Hope this helps.
Jan 11, 2009 | Refrigerators
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Oct 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
