Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I get my tv to switch to digital from analog
    President:
  • Sharp Master
  • 1,779 Answers
Just do Auto Program!
Posted on Jun 14, 2009
How to switch from analog to digital
Flat panel TV (DLP, LCD, LED or HDTV) are digital already.
Your signal inout could be Analog or Digital.
Also STB (Set of Box) or Cable or OTA (over the Air channels) determine if your input signals are Digital or Analog.\
Aug 10, 2016 | Televison & Video
How can I switch from digital to analog?
If this is a CRT then you do not have a choice to get digital over analog. It is an analog TV. You can get what is called a scan converter to convert a digital signal to an analog but you will not be viewing a digital signal. To view a true digital signal you need a digital tv that has a resolution of 720P or higher. Most TVS are 1080P standardize which is the most common.
Feb 02, 2016 | Broksonic TV
How do I switch from anaLog to digital as Samsung TV now showing week or no signal but has been working ok for some years on digital now seem to have switched to analog
Most Samsung tv's change from analog to digital (and vice versa) by entering the same channel number you're watching at the moment, again. If that doesn't help, check the manual for detailed information.
Feb 28, 2015 | Samsung Televison & Video
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Switching from analog to digital on scepter x50 hdtv
All the new flat screen TV's work on a digital signal only. There is no switching from analog to digital anymore. The signal from an antenna is digital now too. There are no analog signals anymore.
Sep 07, 2013 | Sceptre Televison & Video
Connected Auvio Bluetooth speaker to Samsung LN-S3241D TV via digital optical wire and digital-to-analog audio adapter; the sound plays great but the volume can not be adjusted with the speaker controls,...
Check your menu on the Samsung to switch audio out selector. You might have to use ANALOG outputs instead.
you could then eliminate digital to analog adapter.
Analog out uses the RCA PLUGS.
Jan 10, 2018 | AUVIO Bluetooth Portable Speaker
Do I need a converter box for a Sony KD-27FS170?
When a TV hasn't digital tuner, it's necessary to add it a digital to analog channels converter box, but your TV already has digital tuner, you can switch between digital and analog tuning by pressing the digital/analog botton on the remote control.
Feb 24, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
163 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
