Question about Genica MH2001 5-in-1 Hi-Fi S-XBS Wireless Headphones w/FM Radio
Sync Headphones to Emitter Hi-Fi S-XBS
Cannot sync headphones to emitter
My emitter only has a jack and red cord. No white cord. How do I connect it to my TV? (For Hi-Fi wireless headphones)
You'll need an adapter or a cable with the correct ends on both ends of the cable.
Nov 29, 2016 | Televison & Video
They won't sync with bluetooth iphone 6
Probably you won't be happy with my answer but sometimes happens. If won't sync, you can't do anything.. A question of "conflicts" and compatibility. I never could sync my LG headphones with my cellphone even if it did sync perfectly with a Samsung Galaxy III!
Jun 23, 2015 | Beats By Dr Dre Studio Noise-Canceling...
No audio from TV through Wireless Headphone
Unfortunately, this product has a reputation for unreliable operation. Many Amazon users report that they can't get it to work with their TVs. To isolate the problem, try plugging a good set of wired headphones into your television; if you hear nothing, then the TV is at fault. Otherwise, try plugging a different, known-good adapter cable into the TV. If you still don't get sound, then the Genica is broken.
Dec 26, 2013 | Genica MH2001 5-in-1 Hi-Fi S-XBS Wireless...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
No light oh headphones i have 2 batteries in emitter do 2 go in the head set?
pop the side off headset and insert two battires then turn it on ....pop bottom off emitter insert two battries flip swith up one notch to turn it on........the headphones are just an fm radio...push middle button to scan channels and bottom button to change bands...........the emitter sends on an fm signal which the headphones will pick up when you pickup the right channel signal........turn the headset on and off with the volume knob.........if you leave either one on 24 hrs the battries will die since there is no usb power cord as promised in the manuel so be sure to turn both off when not in use
Jan 22, 2011 | Logitech MH2001 5in1 HiFi SXBS Wireless...
I want the user manual of mh2001 wireless headphone
I need manuel for MH2001 HI-FI S.XBS. I want to be able to chat.
Jun 27, 2010 | Logitech MH2001 5in1 HiFi SXBS Wireless...
Logitech soundbridge wont sync
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some good deal on nowadays products.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Sep 25, 2009 | Logitech Wireless DJ Music System (966194)...
Failure to sync
hi, there maybe interference with the signals try in a differnt area.
Aug 04, 2009 | Jwin iLuv i903 Consumer Headphones
Genica MH2001 5-in-1 Hi-Fi S-XBS Wireless Headphones w/FM Radio Logo
18 people viewed this question
Top Genica Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Genica Audio Player and Recorder Expert? Answer questions, earn points and help others
