Question about Kenmore 80809 Microwave Oven
790.80372310 How do I disable the Reminder Beep
GE JES1344SK01 microwave: turn off reminder beeps
I checked my GE micro information and nothing is said about disabling that annoying beep. Guess GE feels it is for your own good, like a noisome nanny.
Jan 02, 2014 | GE JES1344SK Microwave Oven
GE profile microwave keeps alarming "reminder"
test this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2ZpM2PvPs
Jul 22, 2013 | GE Microwave Ovens
GE Spacesave microwave won't work. Display says REM. What does that mean?
"REM" is "reminder". That's covered in your owner's manual.
Here's a sample:
"The Reminder feature can
be used like an alarm clock
and can be used at any
time, even when the oven
is operating. The
Reminder time can be set
up to 24 hours later.
1 Press REMINDER.
2 Enter the time you want
the oven to remind you.
(Be sure the microwave
clock shows the correct
time of day.)
3 Select AM or PM.
4 Press REMINDER. When
Reminder signal occurs,
press REMINDER to turn
it off. The Reminder
time may be displayed by
pressing REMINDER.
NOTE: The REM indicator
will remain lit to show that
the Reminder is set. To
clear the Reminder before
it occurs, press
REMINDER, then 0. The
REM indicator will no
longer be lit."
Jan 27, 2011 | GE Microwave Ovens
Gives beeping noise at regular intervals
On my Danby this was a reminder that you had nuked something and had left it in there. If it stops when you open the door then this is all it is. It should beep about once every 15 or 30 seconds.
Other than that I don't know of any other regular timed beep that my Danby made.
Jan 23, 2011 | Danby DMW1153 Microwave Oven
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Can't cancel out reminder feature
Press Reminder/Clear/0 (zero).
Apr 30, 2009 | Microwave Ovens
No programming tone
On page 11 of the manual:
Disabling the timer reminder tones:
To disable the reminder tones, press and
hold the Timer Set pad for 5 seconds. To
enable the tones, follow the same step.
To shut off all (audible) signals except for error tones and the hidden function signal:
Press and hold the Stop Time pad for5 seconds. A short tone will sound to tell you the signals have been changed. Repeat the above step to turn the signals back on.
If that doesn't work, the next thing I would suggest is a hard reset. Unplug the unit for a minute or so.
Then plug it back in, set the clock and try again.
Dec 03, 2008 | Whirlpool RMC275PD Microwave Oven
Charcoal Filter Replacement
Be sure the oven is disconnected from the wall first. Then open the door. Remove the two screws from the top of the grille. Next, slide the grille to the left to remove it. Before you slide the charcoal filter out, be sure to note how it rests at an angle on 2 side support tabs and in front of the right rear tab. After it's replaced, you can press OPTIONS until you come to the Charcoal Filter Reminder. Then you can press 0 to turn the reminder off, press 1 to set the reminder, or press 3 to turn the reminder on.
Jan 13, 2007 | GE JVM1860 Microwave Oven
Kenmore 80809 Microwave Oven Logo
101 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
