Question about Scotts Miracle Gro Liquafeed Sprayer 6 Refill Combo Pack
MiracleGro Liquafeeder leaks at joint above hose connection. I have purchased 2 more with the same result
How to prime a sand filter pump
use a garden hose connected to house supply to fill the housing and pump head , after that Pump should be able to take over and use water pulled from skimmer , if all your joints and seals are good , if it looses prime ,even after resting for a little while , ck all your joints and seals for leaks ,remember not all leaks ,Leak Out some leak In !!
Apr 23, 2014 | INTEX Sand Filter Pump
Coolant dripping from joint where heater hose connected to engine, I think this leak might be from the mettal joint
This connection is usually the hose end connection to the water pump. As it is just leaking at the connection try disconnecting the clamp, and clean all areas around the cast iron fitting...some light sanding may be required to clean completely...replace the hose with a new one...or re-connect the old one...lubricate the inner section of the hose and use a new clamp...If leak persists inspect the connection for hair line cracks...Hope this helps.
Apr 10, 2012 | Nissan Cars & Trucks
Ariston afa 370x leaking water after wash cycle puddle on floor. no problem with anything else
Hello.
When you are doing your laundry and you notice water on the floor that should not be there. A moderately handy homeowner will be able to identify and fix many kinds of leaks. Doing the service your self can save you the cost and hassle of having a service technician come out. Small leaks lead to large ones quickly, and that can result in ruined flooring and the possibility of mold growth. Fix most leaks in a day or less, with purchased parts from supply houses or home improvement stores.
Here are Instructions and tools Needed to solve the problem
  • Flashlight ,Adjustable wrench ,Flathead and Philips screwdrivers
1. Water Supply Leaks
1 Find the source of the leak. Turn on the machine while it is empty, and then look behind it with a flashlight while the tub is filling. Pay close attention to the hoses, and look for drips or running water. Some drips may start out slow, but gain momentum with continued water pressure.
2 Turn the water off. Often, if the water is leaking from the fitting where the hose attaches to the tap in the wall, you need to replace the hose gaskets. Unscrew the hose from the tap by hand or by using an adjustable wrench. Use a flathead screwdriver to pry the old gasket out. Place a new gasket in the hose connection where the old one was removed.
3 Turn the water on, and check for leaks again. If a leak is at the fitting or elsewhere on the hose itself, replace the entire hose and gasket assembly. Turn the water on again, and check for leaks. If the machine still leaks, check your work, and then look for other causes.
2. Pump Replacement 1Move the dial to the end of the wash cycle to drain the water from the tub. Turn the water off at the wall supply taps.
2 Remove the top of the washer. In many models, the top pops up when you apply upward pressure to the front of the washer at the joint. Sometimes, you may have to remove part of the instrument panel, which is attached with screws.
3 Look into the cabinet around the tub to find the pump. Pumps are either direct-drive or belt-driven. If you see a belt, you have a belt-driven pump. If there is no belt, it is a direct-drive pump. Remove water lines, and take out the old pump. Replace with a new pump, reattach water lines, and reattach the belt, if necessary. Turn on the water, and check for leaks.
Good Luck and thanks for using fixya.
Aug 02, 2011 | Dishwashers
My 96 Toyota Previa has a clogged AC drain line and is leaking into my front pasenger area. I cannot find the drain line to try to unclog. please help!
On my '91 Previa, the drain line comes out of the condenser drain pan directly above the power shaft. The hose makes a turn to go around the power shaft. There's a joint above the curves in the hose. If you take 2 pliers you can wiggle off the bottom piece and then you have a straight shot to take a piece of wire or something and push it up into the drain hose and clear it out. Watch out though, because there's probably water in there and a bunch of nasty junk will come out when you clear it out. Then just put the hose back on the joint & you're good to go.
Jul 20, 2011 | 1996 Toyota Previa
My 1990 toyota corolla is getting hot really fast - i fill radiator up and after 5-10 min the water has evaporated - it appears to be leaking somewhere around the right side of engine (facing front of car)...
Well there are only 3 things that could have gone wrong.
1. Radiator Leak - this means the radiator has developed a hole with via corrosion of the metal parts of simply integrity failure of the plastic parts of the radiator.
2. Hose leak - this could be a hole in 1 of 2 hoses that connects the engine to the radiator. Or it can also be a leak where the hose connects to the radiator (clamp Failure).
3. Water Pump breakdown - this is where the gasket in the water pump has failed and is leaking out the water rather than pumping it.
All the problems above has different ways of diagnosing. but we can probably narrow it down.
1. if the leak is near the radiator then it could be a hose connection, hose breakage or Radiator hole.
2. if the leak is nearer the engine then check the other end of the hose and if its not there then it could only be the water pump is leaking. You can check this if there are water stains on the water pump. The water pump on a 1990 corolla is mechanical turned also by a fan belt. Look for a pulley that has a hose connected to the radiator and that would be the water pump.
Nov 02, 2010 | 1990 Toyota Corolla
I'm leaking coolint from the bottom of my truck and coolint leaked on to my floor inside I need to know how to bypass my heater core thank you for your help and time Oh ya almost for got I have a 2000 gmc...
Purchase a 5/8 to 3/4 hose union and connect the two heater hoses to it. Just remove the two hoses from the heater core to do this. You will not have heat this way although the leak will be fixed
The union can be purchased at most NAPA Auto parts Stores
Aug 07, 2010 | GMC Sierra 1500 Cars & Trucks
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
LEAKING ANTIFREEZE DON'T KNOW IF IT NEEDS A HOSE OR A SEAL. MY CAR IS A 1992 TOYOTA CAMRY
Base on the age of the car it can be few areas.
radiator cap (old)
radiator pin hole leak and/or at the plastic joint.
heater core (check for wet carpet on the passenger floor)
heater hoses
THE WORST
blowing heat gasket.
PLEASE check for white smoke AFTER the car is warm up. 10 minutes after start up.
Is the color of the oil look clear? Vs miky,brown color.
Please check all of the above and port the result on the comment page/window,
I will follow up on it.
Aug 19, 2009 | 1992 Toyota Camry V6
Ice maker is leaking out the back of fridge at joint
There may indeed be blockage inside the joint/or supply line. Depending on the hardness of your water, there can be a considerable amount of calcium or other mineral deposits fouling the line. This sediment will be inside and may not be noticeable from the outside.
However, if you notice crusty deposits anywhere around where you see the leaking this is a strong indication that you may have sedimentary build-up inside.
In any case, the best long-term solution is to replace the joint and evaluate the line surrounding the joint. All the parts involved can be purchased at a local hardware store, and they are not very expensive at all. Attaching them is pretty straightforward as well.
I hope this helps.
Aug 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My hose connection is leaking water
Jonathan, first unscrew the hose connection. Now look into the end of the hose for a rubber seal. The color of the seal may be black or green or red or yellow or some other color. Does this seal exist at all? I once had purchased a hose and found out the seal had fallen out sometime before I got it home. If the seal is there, remove it and get another seal. They are inexpensive, but usually must be purchased in quantities of 10 or more.
Aug 03, 2007 | Kenmore 54501 Dehumidifier
Scotts Miracle Gro Liquafeed Sprayer 6 Refill Combo Pack Logo
59 people viewed this question
Top Scotts Garden Experts
Rod Doney
Rod Doney
JOHN PACE
JOHN PACE
Are you a Scotts Garden Expert? Answer questions, earn points and help others
