Question about Taylor 794 Water Cooled Soft Serve Frozen Yogurt Ice Cream Machine 100%
How to find inlet verse outlet water line on Taylor 794 water cooled unit
Please provide water hook up directions for Taylor 794 water cooled unit.
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
046686 Water Regulating Valve 3 8
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Can you replace just the body part of the water value instead of having to recover and recharge the system?
Yes you can. I have never seen the charged side of the valve go bad. Remove the 4 screws (usually T-20 Torx or phillips) on the "bell housing" side, and replace everything besides that part.
046686-ntrk102vrythapb4yqnobf12-2-0_0.jpg You can order the water valve here if you need it.
Jul 25, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Manual and guide for Taylor ice cream machine model 8756-33
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Slices Concession
Aug 07, 2013 | Taylor Soft Serve 8756 Three Phase Water...
Drive shaft stuck
if you can't get it out thru the barrel then you will need to remove the gear box behind the shaft and push it out that way. you should align the shaft afterwards to not rub also make sure your not lubing the bolt pattern on the shaft. after its out use the cleaning brush and clean the coupling.
Mar 02, 2013 | Taylor 794-27 Soft Serve Twin Twist Water...
Looking at a H84-27 how can you tell if its air cooled or if its water cooled?
Air cooled units will have refrigeration condensers, ie: the fins for air to pass over. Water cooled units have water hook ups and black coils inside.
Nov 02, 2012 | Taylor H84 Soft Serve Frozen Yogurt Ice...
M#794 hopper not cooled while com running freon fuuly charged maybe epr no good / ?
http://www.taylor-company.com/service/resources/op_man/0750_751_754_774_794op0.pdf
Oct 25, 2010 | Taylor Ice Cream Makers
I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
Taylor 794 Water Cooled Soft Serve Frozen Yogurt Ice Cream Machine 100% Logo
37 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
