Question about Horizon Exercise & Fitness
PROGRAM DISPLAY UNIT
IS THERE A BATTERY THAT COULD NEED CHANGING ON MY TREADMILL ? WHEN I TURN ON THE POWER THE DISPLAY UNIT GOES TO SHORT LINES ALONG THE DISPLAY SO UNABLE TO PROGRAM - THANKS LIZ
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Treadmill turns on and belt moves, but cannot
ADJUST THE SPEED SENSOR 1 STEP:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
11_29_2011_4_15_08_pm.gif11_29_2011_4_15_29_pm.gif4step: tight the flexible cable from Keypanel vs Display board , then tight the Display Board connector vs Lower Board( Main Motor Controller) See the block diagram how the Main Motor Controller has 90% of functions of any treadmills. Good luck, sincerely. G-d Bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Nov 29, 2011
ercupa190
  • 12223 Answers
SOURCE: when turning reebok tr3 on the digital display goes off and green light stays on english led and treadmill doesnt work
1) Try to exchange batteries new ones.2) see the diagram adn adjust by 1/8" or 3mms according. 3) tight the key panel flexible cable vs display board 4) then connector display board vs lower board.5) test the main motor controller bOARDEC for 5+vdc, to display board.See the block diagram how the main motor controller has 90% aprox for control functions of any treadmills.sincerely. Merry Christmas.ernesto cuadra , managua, nicaragua. 12_20_2011_7_10_29_pm.gif12_20_2011_7_10_45_pm.gif
Posted on Dec 20, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill has lines accross the display
Dear SIR:
You have possibles cause: 1) Tight the flexible cable or ribbon very well 2) Tight the connector from display board vs lower board 3)Try to clean with spray contact cleaner from Radio Shack the contact for corroded contact.
4) adjust the Reed switch see the diagram 5) Try to RUN the software calibration for easy diagnose and troubleshooting 6) See my personal TIPS for HELP 7) IF the problem persist you have problem with the EPROM or faulty display board.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Posted on Apr 05, 2012
ercupa190
  • 12223 Answers
SOURCE: Power is ON but unable to start program
1) You must have the deck belt is WORN, to due the lack of maintenance , however LUBE the deck belt with 100% of silicone or wax
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.see my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Posted on Dec 10, 2012
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
How to remove password
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
May 17, 2014 | Precor Exercise & Fitness
Removing a user I'd password from a precor 935 2005
• Set User Name
Procedure
Dec 21, 2013 | Precor 935 Premium Series Treadmill
Pass lock reset
• Set User Name
Procedure
Nov 05, 2013 | Precor Exercise & Fitness
9.33i treadmill asks me password as the unlock
• Set User Name
Procedure
Nov 05, 2013 | Precor 933 Premium Series Treadmill
Precor treadmill password default setting
• Set User Name
Procedure
Nov 04, 2013 | Exercise & Fitness
How to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
Password reset
• Set User Name
Procedure
Aug 24, 2012 | Precor 9.31 Treadmill
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
Jan 27, 2012 | Precor 9.31 Treadmill
We forgot the password on our treadmill. How can we reset the password?
• Set User Name
Procedure
Mar 08, 2011 | Precor 935 Premium Series Treadmill
Exercise & Fitness Logo
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
