Question about Whirlpool WTW6400SW Cabrio Washer
My washer will not drain or spin and I get the code ld but if u mess with the motor it will run again
My washer will not spin or drain and pops up with the code ld on it we took the back of and if you move the motor on the pump it will work fine for a little while but then stops working again.
  • 957 Answers
Check the wires going to the motor they could be broken or the plug for the motor could be loose
Posted on Mar 19, 2014
SOURCE: WTW6600SW2 Won't Drain
same thing happened to me just yesterday...
I removed the back end, tilted the washer forward and put books under the back legs...
i slowly drained the water from the tub, by loosening the elbow between the drain pump and black drain hose...
once the water was drained enough not to flow out when I removed the pump...I loosened the elbow and removed the pump, pulled it apart and took out a thin,thin piece of metal that had came from who knows what...replace the pump and works great...(for now)
Posted on Dec 27, 2008
aborcass
  • 2651 Answers
SOURCE: Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Posted on Nov 11, 2008
ngfam1
  • 639 Answers
SOURCE: i have a cabrio washer
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
  • 3 Answers
SOURCE: Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont drain says Ld
I was having the same issues, I replaced the motor/pump, cost about $145.00 and replaced it myself, A repairman will charge up to an extra $100.00 for an hour of work. I ran a load of towels and it ran great and sounded quite. Woohoo im the hero, not!! the very next load the error "LD" came back at the 7 min remaining mark. so i pulled out all the wet clothes and ran a quick wash and watched the progress,the washer was draining but again at the 7 minute mark, it seemed the washer was struggling and not spinning. At this point im thinking i have to replace the spin motor and belts. But i kept getting the "LD" code which does'nt add up. So i crawled behind the washing machine again, took the back off, this time i disconnected the Long drain. I found the best way to get rid of the water in the tank is to unhook the long drain from the back of the frame, there are two(2) white clips on the inside and one(1) black "C" clip on the hose on the back where hose comes out. I used our carpet cleaner, lowered the hose till water started coming out and poured water straight into the hose for the cleaner. Im sure a shop vac will work as well. If you don't have a cleaner or shop vac, just use a large cup you'll get most of the water out, keep a towel handy for some clean-up. After the water level was below hose level in tank, i took the hose off, (you'll need pliers to squeeze the clamp from hose). There it was, my problem, not one(1) but two(2) bra wires stuck in the drain port, causing the float valve ball to be jammed and sending the message to the machine brain to shut down due to a blockage at the drain. Duh hench the code "LD". Somehow the bra wires made there way over the wash plate through the quarter size holes on bottom of wash basin and thorough the tank to the drain port. After reassembling the drain hose and washing machine, my wife has completed several loads of laundry and im on the hero status again. I sure hope this fix will help you get on the hero status and save you $145.00 or more.
Jul 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer will drain druning the initial spin but not during the final spin
LD is a Long Drain code. You mentioned that there is an initial drain so this could be due to some lint or debis caught up in the drain line or drain tank. You will have to remove the black drain line and inspect to make sure all is clear. If you hear a humming noise while the cycle is in the drain cycle, your pump gears could be stripped. If this is the case - the pump will need to be replaced.
The C1 code is a motor current error. The source of the problem might be the motor, but will take more detailed electrical troubleshooting to find out.
Apr 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
