Question about Plumbing
Pegasus 161 263
LEAKING SHOWER VALVE CARTRIDGE NEED REPLACEMENT PART
meBNme
  • 334 Answers
SOURCE: I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Posted on Jan 13, 2009
  • 659 Answers
SOURCE: Unable to find replacement flush valve
You can usually find parts through a plumbing supply house in your area but.....If you go back to Home Depot, go to the service desk and ask to see the DooDads catalog. You should be able to find the replacement items for your toilet in it. Home Depot ownes the largest plumbing supply warehouse in North America. They will ship this item directly to your home at no extra cost. Good luck.
Posted on Mar 16, 2009
  • 52 Answers
SOURCE: ghrohe shower valve leaking: when in off position
Sounds like the gaskets are torn or worn out. Local hardware stores sell replacements for just about every make and model out there you won't need any tools other then some screwdrivers and allen wrenches if this is the only problem. When you open the head to inspect (make sure you turn the water main off in your house just in case) check the plastic housing to see if it's brittle or cracked. If it is you will want to replace the entire unit.
Posted on Feb 11, 2010
jyackle5
  • 8197 Answers
SOURCE: pegasus shower head/schematics
May I get the model # to help you more
Posted on Apr 05, 2010
SOURCE: how to remove the cartridge from my pegasus
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
Posted on May 01, 2010
We have a Model #148-567P for the Shower and need a replacement cartridge because its leaking bad and scoiling hot water. Please HELP!
Warning: Improper hot water tank temperatures can cause bodily harm!
I suggest until this is fixed, turn down the temperature of your hot water tank, not only will you run less risk of scalding; but, you'll be surprised at how much money you'll save.
That being said; I'm not sure what you mean by cartridge. Usually cartridges, if they exist are to filter the water, so it's not clear exactly what you mean.
Here's a link in Fixya that might help your problem.
http://www.fixya.com/tags/pegasus_k800_148_567p/shower_hardware Questions Answers for pegasus k800 148 567p Shower Hardware
Sep 03, 2015 | Home
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
How to remove the cartridge from my pegasus shower/bath faucet. the instructions are not very good.
Oct 18, 2009 | Union Pegasus F1228100PBV Series 5000...
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
Why is it that when I turn on the water on my Pegasus K800 tub and shower faucet, water comes out of the spout and the shower head. It is brand new
Your diverter valve probably has a loose washer or seat. It could be defective, but try to tighten the washer and seat first.
Regards, --W/D--
Jul 20, 2009 | Pegasus Technologies Home
Replacement cartridge for the Fontaine a NF-VCTST-BNV-TSRVH
efaucets.com 1-800-891-0896 they are an authorized Fontaine Dealer.
Jan 29, 2009 | Fontaine NF-VCTST-BNV-TSRVH Brushed Nickel...
Jan 13, 2009 | Union Pegasus F1228100PBV Series 5000...
Plumbing Logo
186 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
