Question about Frigidaire Kitchen Ranges
F11 ault code. what does that mean?
I am getting a fault code of f11, please help
  • Official Brand Answer
  • 2,267 Answers
Hello Polly, this is Z. I am happy to assist you!
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Posted on Apr 03, 2014
Frigidair range I would like to know what f11 means
Hello, Floyd -
Without knowing the model of your Frigidaire range, I cannot look for the owner's manual for your particular model and find what F11 (a fault code) means for your specific appliance.
However, I did find a web page listing fault codes for newer Frigidaire ranges. See the information here:
http://www.applianceaid.com/newer-frigidaire-fault-codes.php
From that information, the EOC (Electronic Oven Control) may need replacing.
Dec 22, 2017 | Kitchen Ranges
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Kenmore gas range F11 error code
    The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
    Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
    F11 - Drainage fault
    This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
    Background information:
    After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
    Cause: Drain blocked.
    Remedy:
    1. Clean the on-site drain.
    2. Check the sump drain.
    3. Check the filters.
    4. Check the heater pressure switch and replace it if necessary.
    Cause:
    Ball in non-return valve in sump has not opened (e.g., jammed).
    Remedy:
    Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
    Remedy:
    Clean the drain pump and its impeller.
    Cause:
    Drain pump defective.
    Remedy:
    1. Check the voltage supply to the drain pump.
    2. If correct voltage is present, check the drain pump motor winding.
    3. Replace the drain pump, if necessary.
    Cause:
    Foreign objects in heater pressure switch.
    Remedy:
    Check the heater pressure switch for blockages and correct switching point.
    Cause:
    Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
    Remedy:
    Replace the heater relay.
    In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
    Hope ths helps.
    May 20, 2011 | Dishwashers
    What does code F11 mean? How can we get teh beeping to stop?
    F11: Disconnect power, wait 30 seconds and reapply
    power.
    If fault returns upon power-up, replace EOC.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 04, 2010 | Kenmore Elite 44173 30 in. Electric...
    My dryer keeps flashing f 11 wht does this mean
    Fault code F11 means that the pump is not working,
    check the pump connections and the pump itself.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
    Dec 21, 2009 | Hotpoint Dryers
    My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
    Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
    Please leave feedback.
    Thanks.
    Nov 12, 2009 | Hotpoint Dryers
    F11 fault code
    Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
    1, Power off at the machine. Do the next 4 steps within 3 seconds.
    2, Press Temperature Button in.
    3, Power on
    4, Release temperature button
    5, press Soil Type button
    You will now hear the door lock release so you can get to your pants.
    Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
    I am sure it would help you to resolve the issue.
    God Bless.
    Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
    FAULT CODE F11
    F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
    Feb 08, 2009 | Whirlpool AWM8143 Front Load Washer
    Kitchen Ranges Logo
    218 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
