Question about Lakewood Dryers
I'm trying to clean the Lakewood Air Circulator, Model WC2000. The Instructions say to insert flat screwdriver into 4 locking tabs, but can't find the tabs! Help please
Model WC2000, purchased in 2009. The front plastic cover seems to be one piece. I cannot find the "locking tabs" in which I'm supposed to insert a flat screwdriver and unlock the tabs. I'm giving it away tomorrow, and really MUST clean it.
  • marsh_ks Mar 22, 2014
    I've been asked to add details. First, this is not like a regular fan, with a metal "cage". The covers, front and back are plastic, and sit in a plastic frame. The manufactures, Lakewood, call it an "air circulator" and not a fan. I don't what additional details I can provide.
2 Suggested Answers
  • 79 Answers
SOURCE: Lakewood 16" Pedestal Fan- Control Switch gone bad (probably)-
I have seen a number of oscillating fans where the push-pull knob just pulls off. It will require a serious pulling effort - straight up. Do Not use any tools. You may have to have a helper hold the fan while you pull the knob.
After the knob comes off, push the shaft back down with your finger to allow it to clear the housing.
Posted on Jun 11, 2008
I have 2 Lakewood table top fans that need cleaning..I can't get the front grill off...the screws will not turn..how can I open this fan ????I am desperate
sounds like ya screws are stripped in the plastic housing if you can keep trying im sure the fan will open but if not go around the sides with a flat head screw driver till it pops open i got a few sorta like that once the screws are off go around the sides with a flat head screw driver and it will pop open
May 26, 2014 | Lakewood 2210 Fan
How do I take apart fan
Hi, if you look inside the grill from the back side, you will see there are small snaps inside near the edge of the cover. The snaps go around the entire cover and are about 3-4" apart.
I used a flat tip screwdriver to get push the tab up from the back and the inside of the grill. When you push up the tab a bit, then slide a small flat tip screwdriver on the outside lip of the front grill. You will have to do this all the way around until the cover snaps off. Putting it back on is a breeze because it just snaps together.
***AS ALWAYS SAFETY FIRST !! NEVER WORK ON ANY APPLIANCE When it is plugged in !! ***
Hope this helps.... =)
May 25, 2014 | Lakewood 2210 Fan
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
How to clean lakewood 2210 fan
Hope this helps.... =) good luck
Jun 28, 2012 | Lakewood 2210 Fan
Lakewood fan 2210 manual
Hope this helps.... =) Hopefully you won't need the manual and im pretty sure they won't tell you how to take it apart either.
Jun 19, 2012 | Lakewood 2210 Fan
How to clean blades on lakewood fan 2210
Feb 20, 2012 | Lakewood 2210 Fan
Lakewood 2210 table fan.. It wont come apart to clean the blades and such.
There are NO Screws holding the front grill on this model.
Aug 04, 2011 | Lakewood WC-2000 Box Fan
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
How to open keyboard
look for a thin piece of plastic strip that runs the full width of the keyboard near its top. Pry this off gently starting with a jewelers screwdriver (careful not to score plastic). after this is out, lift the keyboard out and disconnect the electric flex circuit.
Jun 08, 2007 | Fujitsu AMILO D-8830 Notebook
Dryers Logo
50 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
