Question about HP LaserJet 3030 All-in-One
HP LaserJet 3030 Printing comes out light but copies are fine.
My Laserjet 3030 prints faint/lightly it will print light images whether it is coming from a computer or is one of the demo/configuration pages. However when using it for copying the copies come out just fine. I can't seem to figure out where the issue is coming from. I have tried resetting defaults, and since the copies are coming out fine one would think the toner and fusers would be ok.
    Habit-Forming:
  • 45 Answers
Have you calibrated your printer after changing ink cartridges?
Posted on Mar 19, 2014
5 Suggested Answers
SOURCE: HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Posted on Mar 17, 2009
POCBM
  • 121 Answers
SOURCE: HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Posted on Mar 22, 2009
  • 1335 Answers
SOURCE: Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
Posted on May 04, 2009
salamoxx69831
  • 3 Answers
SOURCE: HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Posted on Jan 20, 2014
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 Paper is crushed from top right edge when printing/copying. How can/do I fix this? I have used a heaver weight paper and it does not get crsuhed, however the print is usually smudged right...
Try reseating your Ink Cartriges first then try printing to see if the error still appears, if it does try reinstalling your printer drivers... make sure you check your printer cables if they are conencted properly to your computer after reseating the cartriges.
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
LASERJET 3030 PRINTS ONLY 1 COPY VISTA 64
Well go to file and click on Print... this will bring up a list of settings for your printer as well as the list of printers. There you should see a box that says number of copies.
Dec 03, 2008 | HP LaserJet 3030 All-In-One Printer
LaserJet 3030 only makes one copy
in stead of trying to fix hp's **** equipment throw there junk away and dont buy hp equipment
Nov 22, 2008 | HP LaserJet 3030 All-In-One Printer
Will not print copies
printing from indesign, the page goes through to printer, printer receive light flashes, but the page come out.
May 14, 2008 | HP LaserJet 5550 Printer
LaserJet 6L Prints Outlook content too light
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
HP LaserJet 3030 All-in-One Logo
141 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
