Question about NRS Stex 8020T Treadmill
Wierd sound I have a problem with my treadmill Stex8020t. I have 2 of them and one is working just fine, but the other sounds really wierd lately, it sounds like kind of buzzing, and when i shut it down, sound continues for next 10 or 15 seconds and after that stops even if led screen and everything are off power.. Anyone have a clue what might it be
Treadmill starts moving up and down when key is on. How to fix?
This happened to me as well. As wierd as this sounds, Rub/Massage all of your console keys well because believe it or not, they get stuck. While unplugged and without the magnetic key "inserted". Plug the machine back in and "insert" the key. Allow the machine to do the full incline and decline sequence if it decides to do so. Once this happens the machine should allow you to work the console buttons without any issues. At least this is how I was able to fix mine while on the phone with the Gold's Gym technical support. Hope it helps.
Sep 24, 2015 | Golds Gym Trainer 410 Treadmill
My asus adapter was working fine and now somehow it wont charge. Led on adapter is not going on and adapter makes wierd sound. Dint use adapter couple of days and then it started working again...and now...
My best bet is that the adapter is overheating. I have seen similar issues when I used to do computer repair. As far as I know there is no easy way to fix this besides using it in a chilled environment. Um... other possible problems with the same recomended course of action are: some how a wire got lose inside, a liquid got spilled on it by somebody or something, or it sustained a jarring fall (not likely).
Sep 08, 2012 | Computers & Internet
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
Jun 21, 2012 | 1995 GMC Sonoma
I have a wierd "roaring/whining" noise on my RT.
possibly a rear axle bearing. they do make a roaring and whining sound when driving.
Feb 14, 2011 | 1999 Dodge Dakota
My scooter makes wierd humming noises
This sounds like (passing) resonance -- a natural phenomenon. You might be able to eliminate it by just tightening some bolts in the exhaust system -- or, it may never go away, or it may stop of its own accord.
May 13, 2009 | 1993 Ford Mustang
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
Clicking noises
check to make sure the wires going to the main fan are not hitting the blades.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Only two of the speakers are working
have you used the mic input connection as this is used to split the channels
May 21, 2007 | Logitech X-530 Computer Speakers
NRS Stex 8020T Treadmill Logo
Top NRS Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
