Question about Peg Perego Vespa Scooter
Free scooter repair manual
Gas leaking from carburetor when engine not running
  • 3 Answers
Sounds like the float is stuck, not floating(sunken ship), out of adjustment or the needle in the bowl is one of the above. It's a simple
fix- take the bowl off the bottom of the carb. and inspect. Until then turn off the gas when it's not running. Here's a link for more help
http://vespamaintenance.com/elec/diag/index.html
Posted on Mar 23, 2014
My 2007 Sachs City 125cc idles ok but misses when throttling up. Any ideas? Also anyone know where to buy a repair manual for this FYM FY-125-13 scooter
Hi, Paul and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Message Board Motorcycle USA
Why is the engine bogging under acceleration Suzuki FA50 Moped
ScooterCommunity
Sachs Bikes MadAss 125 Repair Instructions
Scooter Wreckers used spare parts for scooters scooter spares
Sachs Bikes MadAss 125 Owner Manual
Mar 15, 2017 | Sachs Motorcycles
My 50cc Scooter has a brand new carb but gas is leaking from overflow ???
Hi, Kim and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.49ccscoot.com/manuals/Hyosung_SF50_Service_Manual.pdf
50cc scooter parts QMB139 49cc 4 stroke parts moped parts QMB139
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 04, 2017 | Motorcycles
My 50cc kymco scooter starts but when you pull the throttle back it cuts out
Hi, Christopher and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike idles perfect but dies when given the slightest amount of throttle 93...
starts idles stalls giving gas Scooter Doc Forum
scooter dies if give it throttle
http://www.scootermasters.com/manuals/kymco%20People%2050-complete.pdf
Aug 27, 2016 | Kymco Motorcycles
I took scooter for a ride everything worked fine get back to garage and fuel is leaking out of carborator to which it drained the fuel tank. Do I need a new carb or what's the problem.
Jason, You can replace carburetor or have the old carburetor rebuilt to fix your gas leaking problem, either float is stuck or if carburetor equipped with a solenoid shut off, are the actual problem likely.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Carburetor Rebuild Cleaning Instruction Video
3 50cc Scooter Moped Carb Theory and Common Carb Problems
How to clean scooter carburetor
rebuild scooter carburetor Google Search
Jun 18, 2016 | Motorcycles
2008 150cc Znen scooter. What causes it to bog down at 55-60 mph?
Hi, Ty and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in the fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Headlights melting Engine bogging down
Yahoo Groups
SportiqueScooters com Scooter Buyers Primer http://www.carlsalter.com/pdfs/Znen_ZN250T_D.pdf
Gy6 50cc 150cc Scooter Repair service Manual Download Manuals Technical
Mar 06, 2016 | Znen Motorcycles
Yamaha scooter
Hi, Anonymous and the usual suspects are:
13. Multi carburetors not in sync
Starts then stalls 49ccScoot com Scooter Forums
Scooter Troubleshooting Scooter won run All about Scooters
Yamaha XC50V Service Manual
OEM parts for Yamaha
https://www.manualslib.com/manual/558548/Yamaha-Xc50w.html#product-VINO XC50V
Feb 16, 2014 | Yamaha G5 Motorcycles
My cpi oliver runs fine for first five minutes then sputters.
2. Spark plug cables in bad condition and leaking.
4. Faulty ignition coil, module, and or sensor.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
16. Damaged intake or exhaust valve.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day.
Archived Scooter Running Questions Runs Slow Bogs Down or Is Rough
https://groups.google.com/forum/#!topic/alt.scooter/jwRUQITS9lA
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
https://scootergrisen.dk/scooterhjemmeside/download/cpi_oliver_brugermanual.pdf
Jul 16, 2012 | 2011 Cpi Oliver City
1989 Yamaha Razz stalls when throttle applied
Hi, Dstelte and the usual suspects are:
13. Multi carburetors not in sync.
Razz wont staY RUNNING Scooter Invasion
Razz 88 Bogs up hills and full throttle
Yamaha SH50 Razz 50 Scooter Workshop Service Manual 1987 2001 Download... $10
Yamaha RAZZ SH50L Owner Manual
Jun 27, 2011 | Yamaha Motorcycles
Peg Perego Vespa Scooter Logo
83 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
