Question about Vacuums
Ryno 180 vacume
Over heats quickly and shuts itself off. Have cleaned it well but must be missing something and cannot find the manual or anywhere to look it up on line. Please help
Bring it in to me at 206 west lordeman kokomo Indiana 46901 or call 765-236-7524 and ask for Joshua for a quick and cheap fix that will last forever under proper running conditions
Posted on Mar 21, 2014
Testimonial: "Joshua I would love to bring it to you but I think Indiana may be a bit far from Utah, But I do thank you, I wish someone could tell me who makes it so I can get a manual, I did finally get it apart, cleared out 3 lbs of dirt and hair and runs great, Thanks too everyone of you."
2 Suggested Answers
  • 46 Answers
SOURCE: Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Posted on Jun 18, 2008
MY NEATO VACUM , IS SAYING SOMETHING IS STUCK IN BRUSH CLEAN ! I CLEANED IT BUT STILL SAY IT STOP,
The bearings are dirty so heating up and waking the voice alert. Take out the brush and scrub the part it sits in. It'll be packed with something nasty. Rouge fishing .inexpensive wrapped in there will burn away the plastic seating. Keep your equipment clean and it will perform and last much longer
Feb 01, 2017 | Neato Vacuums
My lift off revolution vacume shuts off
Hi Kathryn! Your Lift-Off vacuum is equipped with a Thermal Protector that will turn your vacuum off if the motor starts to overheat. This can be caused by dirty filter or reduced air flow.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1405&cid=ccsocial
Mar 03, 2013 | Bissell 37604 Lift-Off Pet Bagless Upright...
I've got the Hoover #uh70035b, it worked great for a long time, but now after about 5-10 mins it then shuts down and after a "long" while it will work again. It's like it's over...
go to hover for the owners manual sounds like it might be a clogged internal filter stifling the normal flow of cooling air around the motor
Dec 09, 2017 | Hoover Vacuums
No Power
if this vacume get stopped up the motor will heat up and shut down try and see if the hoses underneith and back are clean and open and also make sure all 3 filters are either new or clean. that should help it form shutting down
Nov 28, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Was vacuming floors and it just q2uit no power
The most common thing would be a bad cord. It could also be a switch, the heat sensor or fuse(depending if you have one on that particular model). All of these can be tested with a continuity tester.
It could also be the motor, but usually the motor tends to smoke, stink, and spark before it shuts off completely. Do do a quick check to see if it is the motor you can manually turn the brushroller(if the belt is still good) and that will rotate the motor a around and sometimes that will make it kick back on if it is the motor. Now that probably won't fix it. It might sound terrible, but you'll know what the problem was.
Some vacuums have a reset switch on the machine that could have been tripped. They are usually on the back of the machine towards the bottom. Not all vacuums have these, but it's something to look for.
If it overheated, you just need to let it cool off and try it again.
I hope one of these suggestions helps. Good Luck
Nov 25, 2008 | Eureka Vacuums
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacum keeps turning off with warning lights
Actually the problem is that you need to change your control valve. The motor has an internal thermostat on it already so the chances of you burning the motor out are very slim. By changing the control valve, you will solve your problem. Very simple and quick fix.
Sep 22, 2008 | Electrolux Epic 6500 Vacuum
Vacume Overheating
Jun 18, 2008 | AEG Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
